Question about Xerox Phaser 6180N Laser Printer
I cannot print legal documents from tray 1 of the xerox 6180
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
  • 30 Answers
SOURCE: Xerox 6360dn, Tray 2 makes loud grinding noise
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Posted on Dec 15, 2010
termistor
  • 82 Answers
SOURCE: Xerox 6180 MFP makes copys that are blurry and
I think attracting scanne(copier) be cleaned is probably dusty inside
Posted on Apr 04, 2011
SOURCE: I have a Xerox Phaser 6180. I have not had any
I have 4 of these printers and when we print lots of manuals in full colour and duplexed the printers occasionally get to hot and need to cool down. After a 1/2 hour they are good to go again. I wouldn't worry about it, it happens only when it gets lots of use and I have never had anything go wrong with the printers after these errors
Posted on Sep 25, 2011
  • 18 Answers
SOURCE: Xerox Phaser 6180 keeps saying load papertray with
When you adjust the length guides there are 3 little white switch actuators that eith do or do not actuate three little white switches inside the machine which tell the machine the position of the length guide.
For 11"paper only the bottom one should be sticking out to actuate the bottom switch inside the machine.
Make sure they are intact and that no torn off piece of paper is holding a switch actuate.
If you rmove the tray with a flashlight you can see the three switches inside the machine on the right about 2/3rds of the way back.
They should move freely but they do not go click when you press on them
I don't see anything that monitors the width of the paper in the tray..
If all that works, time to call service.
Posted on Aug 20, 2012
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
How do you print two sided on xerox 6180 phaser
I expect you have to put the paper in the other side up. however if you do you could spoil the first side as it will melt the wax again when it's fusing the second side!
Good Luck.
Jul 31, 2014 | Xerox Phaser 6180N Laser Printer
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
Xerox 6180 James at Tray 1 mpt every time!
Your lower trays are programmed incorrectly. Change the size and or the paper type back to letter and plain paper
Aug 23, 2012 | Xerox Phaser 6180N Laser Printer
When we print to Xerox Phaser 6180 the print job prints the first page from tray 2 and then wants tray 1 loaded with paper to finish the print job. The paper in tray 2 is 8.5 x 11 the same that is...
I suspect the machine is on a network and the driver is installed on the server. Your workstations driver properties are probably not the same. i have seen this problem quite a few times and its always been down to configuration and not a fault of the printer. Basically a printer prints what it is sent and to where it is sent.
Good luck
Jun 01, 2011 | Office Equipment & Supplies
My hp laserjet 2420 printer won't print out my bottom text of my legal size document. when i preview my print it cuts off all text at 9.5'' . what's wrong? my margin's are all set to 1'' and i customized...
Do NOT use customized paper. Set your paper tray to LEGAL paper. Set the tray as LEGAL in the printers setup-menu. Make sure you choose LEGAL in the printout-dialog-properties. Then it should work. Good Luck.
Aug 14, 2009 | HP Hewlett Packard LaserJet 2420 Printer
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
Xerox Phaser 6180N Laser Printer Logo
26 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
