Error code 004-10 canon ir6570 - Office Equipment & Supplies
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Canon iR6570 waste toner
look on the right rear of the machine, there should be a door with 2-4 screws. A big white plastic container should be there, remove dump toner and seal bag, replace. Make sure it is sitting properly, it uses a weight system.
Posted on Sep 08, 2008
SOURCE: sir ; i have a canon ir6570 machine,it was
this problem due to an over current has been detected in the toner feed motor,you must check the connector or replace the motor
Posted on Aug 01, 2010
  • 149 Answers
the waste toner bottle is stuck int he hopper assembly
try removing the toner bottle and reseating it
if it doesn't work then you blew a fuse on the dc controller board
Posted on Aug 22, 2010
babaprithi
  • 372 Answers
SOURCE: what is error code E247-0004 in ir6570 Canon
u have to use the same counter and serial pcb . no way to bypass it as far i now.faced same problem
Posted on Apr 19, 2012
Testimonial: "Yes from other machine both pcb replaced problem shortout"
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
I WANT TO INSTAL IN MY PC 64BIT DRIVER OF CANON IR6570 MACHINE
You can download the driver for your Canon IR6570 through the link below :
http://tinyurl.com/5v734xz
Choose your operating system then start the download process. You will encounter a "capcha" prompt so ensure to input the correct code. Example :
Thank you for using Fixya.
Feb 20, 2011 | Computers & Internet
Sir ; i have a canon ir6570 machine,it was coming an error code e025-001<br />what is the problem?<br />pls give me a solurion.<br />thank u
Aug 21, 2010 | Canon IMAGERUNNER 6570 Copier
Jul 30, 2010 | Canon IMAGERUNNER 6570 Copier
We have an f105 error what can we do?
Hi...
I Have Canon Ir5570 but i want up speed to Canon Ir6570.
I want Binary file for FRAM COUNTER Board In Chip IC #MB85R256 form Canon Ir6570.
And I want Binary file for Serial Board In Chip IC #BR93LC46F-W form Canon Ir 6570.
Dec 29, 2009 | Toshiba e-Studio 350 Copier
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
jasbo
jasbo
