Question about Fisher and Paykel AeroTech Double OD302 Electric Oven
OR90LDBGX1 not working - Fisher and Paykel AeroTech Double OD302 Electric Oven
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Burners work, broiler works, oven doesn't work
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 27, 2011 | Ovens
I have a cookmaster 100 dual fuel the clock has gone out and the fan oven has stopped working the other oven and the grill stil work ok
If the clock is not working, then that is the reason the main oven and fan are not working, as they go through the clock timer..
You need to get the clock working for the oven to work.
Hope this helps.
Jan 06, 2010 | Ovens
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Oven wont work
ok an oven won't work withought the time set i am not sure which one you have but usually if you press all the buttons together the oven will then work
Apr 03, 2009 | Kenmore Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Open Questions:
See all Fisher and Paykel AeroTech Double OD302 Electric Questions
Fisher and Paykel AeroTech Double OD302 Electric Oven Logo
32 people viewed this question
Top Fisher and Paykel Ovens Experts
Dan Webster
Dan Webster
Flipper
Level 1 Expert
 Fix Your Board
Fix Your Board
Are you a Fisher and Paykel Oven Expert? Answer questions, earn points and help others
