Question about Home Security
How to change the code on the vcode100 stand alone keypad
It is an stand alone shower not a tub shower
OK, so go to the store where you bought it and change it.
They sent it by mail? Return it
with the note:
Sep 22, 2015 | Home
Tip
Making the ebox a stand alone system to work with any tv
I have place this info on another site so I'll give you a link ,by making the ebox a stand alone unit most of your problem will be resolved because the ebox will no longer look for the Philips tv signal .
You must have a remote control for the ebox to make this work ,I hadv had my ebox hookedup to a regular computer LCD screen for 4 years and neve had any problems with it since the ebox was change over to a stand alone unit. Here the link good luck
http://www.lumenlab.com/forums/index.php?showtopic=13973
on Mar 03, 2009 | Philips E-Box FTR9965 DTV Receiver
Error code c0510 for a minolta cs pro
Change the fusing unit heatre lamp thermistor,reset the error code.
Jan 22, 2012 | Minolta Office Equipment & Supplies
Front right burner will not fully heat up, and oven sometimes stops working with a "F2" reading.
Code F2 errors mean that something is wrong with the keypad; I suggtes check the keypad if is firmly connected with the control board, then press "Cancel." If the error returns after 1 minute, you will have to replace the keypad. Also, try check the relay board (its possible you will have to replace). It may be a stand alone board or it may be part of the ERC (Electronic Range Control). If you know how to check you won't have to call a tech.
Hope this helps.
Dec 09, 2010 | Ovens
How to change motorola v3i keypad - only the silver thing
you can change the Motorola keypad for that you need to contact the nearest Motorola service center for that
Oct 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
64 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
