Question about Canon imageRUNNER 550 Printer
Canon 550 I would like to copy 3 pages, and have the paper pulled from 3 different drawers. Is this possibl? And how do I do it?
  • 186 Answers
Are all 3 pages the same size? If so, you must copy them one at a time and manually choose which drawer you want to draw from.
Posted on Jul 10, 2007
I have a Canon Pixma MX310, when I want to copy a document, the paper does not feed properly and I'm using the appropiate type of paper but every time it jams. May be the roller is dirty, but I don't know...
Accessing the take-up rollers can be difficult. Use a lint-free cloth dampened with a mild soap solution. If you have printed a lot of pages, paper 'fluff' can coat the rollers causing slippage. You may need to use a more aggressive cleaner (metho or similar). Another possibility is an uneven tension in the springs in the paper drawer. Check that the drawer when returned to correct position is holding the paper level.
Sep 03, 2010 | Canon Office Equipment & Supplies
When we run 50 or more copies, we get an error message about 'wrong paper size' . The last copied page will be slightly off the page. If we open and close the paper drawer, the copying will resume. The...
Try changing your paper from different brand.
If problem persist, there's a timing problem with your leading/trailing edge. Usually the HVT board is replaced.
Aug 30, 2010 | Canon iR 2016i Black and White Copier
Tried to copy a book and the copier started pages were blank
maybe it would help if you try not to use the automatic paper select button or use the manual paper select try. set it to 11 x 8.5
Jan 31, 2010 | Canon Office Equipment & Supplies
Canon PC770 Paper Tray Does not Close Completely
After numerous attempts, the drawer finally slid in and worked --- until today.
New problem - drawer wouldn't come out and indicator showed the paper was out when machine had paper.
Removed screws from bottom of copier - couldn't completely remove the metal plate, but was able to pull it out enough to allow the paper drawer to be removed. Only thing that could be seen as potential problem was a spring hanging down the back that did not seem to be attached to anything. (heavy duty, about 7" long and 1/2 inch diament)
Removed screw, replaced screws in bottom plate - drawer slid in fine - turned on and ran copies just fine. Don't know what the spring was for - but copier is working for the moment.
Jan 03, 2009 | Office Equipment & Supplies
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Oct 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Canon imageRUNNER 550 Printer Logo
old marine
old marine
