Question about Dell XPS M1330 Laptop Computer PC Desktop
Vertical lines, screen freezes, laptop shuts down
I was working with my laptop then blue, yellow, gray lines appeared in the screen. this happened three times already and the screen also freezes when this happens and the laptop shuts down by itself after a while. its a dell xps m1330. pls help!
  • Anonymous Feb 16, 2009
    Had this same problem on 2 Dell M1330 computers. Plus heeps of other issues too.
  • Anonymous Mar 14, 2009
    I have the same problem. Its a bummer. It has been partially resolved by upgrading the memory by 1GB and loading the latest BIOS software from Dell. I think its something to do with overheating but my comp only crashes once a day now instead of constantly - whoop de doop
Problem is with the integrated graphics card so replace Motherboard as its an known issue in this system model
Posted on Feb 04, 2009
  • 85 Answers
It most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
Posted on Jan 24, 2009
Wide gray bar with thin green, yellow, pink and blue stripes appears when tv is on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Hi, i have AL1716 monitor (2 year old). Recently, there is a blue vertical line which appears on and off sometimes in the monitor. Can anyone suggest on a solution
Is the vertical line always at one location ? (on the screen)
If so, it appears that the video card/driver (on your PC or laptop) may be causing the line to appear occasionally ... i.e. flaky ... and it will likely fail (completely) in due time. To confirm it's the video card, try using another monitor (long enough) to see if it happens.
[ The line may also be caused by "dead" pixel on the screen ... but this usually happens on randomly located pixels on the screen, not on one vertical line. But, it may also be a possibility ... in which case, using a different monitor may prove it one way or the other ]
Aug 11, 2010 | Computers & Internet
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
Buddy its not the graphic card its your motherboard which is not working properly . it might be repaired but i suggest you to buy a new one..
Mar 17, 2010 | Computers & Internet
Vertical colored lines have appeared in my display.
turn on the system by pressing FN key and then the power but this should start up the onboard diagnostics let me know if the line are displayed during the diagnostic if it does the its the graphics. when it ask you if vertical or horizontal bars were displayed. select N so it can test the LCD panel if the lines are displayed there then it is your lcd panel.To make sureyour lcd panel is fine it will display solid colors.
Jan 20, 2010 | Dell Latitude D510 Notebook
Windows Vista freezes while loading up& Blue Vertical Bars appear
Hi
Reflashing the bios doesn't make any difference.
Check in the BIOS Screen whether notebook scree has the same issue if it is the same then it is a hardware issue if it is fine in the bios screen then need to run the hdd and memory test
After the test result we can decide next steps
> If hdd and memory test passes - then reload the os.
To login to bios - Reboot the system and keep tap on f10
Apr 28, 2009 | HP Pavilion dv9000z Notebook
Lines on screen
This is a fault with the TFT display controller, Unfortunately this kind of fault is not User Serviceable, If this item is within manufacturer's warranty send it back and they should fix it for you, (REMEMBER TO BACK UP YOUR DATA as they may choose just to replace the whole thing)
Oct 03, 2007 | Dell Inspiron 8600 Notebook
Dell XPS M1330 Laptop Computer   PC Desktop Logo
661 people viewed this question
Alun Cox
