Question about Dryers
Model lgb6400lwo heats up when first started but wont heat on second call for heat
2 Suggested Answers
daddy1264
  • 76 Answers
SOURCE: gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Posted on Sep 16, 2009
Testimonial: "thank you "
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Heat cycles off too often
Proper make & model of furnace please.
Jan 03, 2013 | Coleman Heating & Cooling
Dishwasher clean light blinks constantly, can't get washer to start up and wash. Buttons will light up but it wont start.
Hello, Thank You for using FixYa. I will be helping you today.Try pressing heated dry,Normal,Heated dry,Normal and all lights should come on if they do wait like 5 seconds and hit cancel and see if the unit will start. If this happens again it may be a heating issue.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | KitchenAid Dishwashers
Dryer starts to heat up and then heat element stops after about 30 seconds. if i reset the breaker it will do the same. if i just restart it soes not try to heat up
I would say it may be the Thermal Fuse here is a website to check it, and how to open the dryer. of course on the site the other things that may cause no heat: heating element, thermostat, and timer motor. it will show how to test these,also. Hope this helps Tim
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 25, 2010 | Whirlpool WED5200T Electric Dryer
Gas dryer wont dry close
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Dryer heating problems
If this is a gas dryer, this is commonly caused by bad gas valve solenoids. Please post back with your make and model so I can verify your configuration and assist you further.
Jan 25, 2009 | Dryers
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Dryers Logo
53 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
