Question about Vacuums
Bissell pro heat 2x healthy home brushes wont turn
The brushes won't turn you can turn them manually but they don't turn with the machine
  • Official Brand Answer
  • 315 Answers
Hey Brenda! Here's a link to troubleshooting steps for the brushes not turning.
http://www.bissell.com/FAQDetail.aspx?id=1128&cid=ccsocial
Posted on Jan 16, 2013
SOURCE: Bissell Healthy Home Vacuum
easy fix- mine did this too for a while bfore I figured out the handle wasn't aligning properly where attached. Give it a smack to realign it and it works again
Posted on Jun 08, 2009
SOURCE: Bissell Pro Heat 2x steam cleaner, problems!
I took the side plastic protectors off because my brushes stopped working. I found one belt almost broken (held together by the fiber to the interior) and when I moved the brush rollers, I found mucho dog hair on the ends. Your rollers might be removed and see if you have the same problem. IT just takes two screws on each end to do this, so if your belts are good, take a look at each end where the metal post goes into it. I have two dogs and their hair is just everywhere!
Posted on Jun 25, 2008
SOURCE: My Bissell Pro-Heat 2x 12
my bissell 9200 won't release water or solution when the trigger is pulled.
Posted on Nov 20, 2008
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell healthy home vacuum roller won't spin
Hi Helen. Your Healthy Home vacuum has a lifetime belt. If the belt needs replacing, you should bring it to one of our Authorized Service Centers for repair. Also, here is quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1394&cid=ccsocial
Here's a quick link to assist you in locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Apr 05, 2013 | Bissell Healthy Home HEPA Bagless Upright...
Brush Bar not turning on a bissell pro heat 2x
Here is the Instruction or User Manual for the 9500 series machines
will give instructions how to check and change drive delts
Dec 12, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
The brushes on my new healthy home vacuum wont rotate when the machine is turned on how do i access the belt location
If you turn the vacuum over so you can see the brush roll, there is a brush cover that is held on by (4) screws. Remove those screws and the base plate cover will come off. With the base plate cover off you can access the roller brush an belt. If you need a replacement belt you can get it here:
http://www.vacbelts.com/bissell-healthy-home-belt.htm
Oct 23, 2009 | Bissell 5770 Healthy Home Bagless Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
557 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
