Question about Philips 170C4FS 17" LCD Monitor
Picture problems i have problems with my picture quality ,photos and pictures are just like white dots the screen is flashing white dots and it is getting harder to see what i am looking at on the screen please tell me what i need to do to restore the picture quality back to it's original settings
  • paul johnson Jul 10, 2007
    it's just like black and white dots covering all dark pictures shadowing one minute it's ok the next it's not
    Genius:
  • 2,985 Answers
What are normal things like text files and the desk top like? If it only photos that are problematical then it won't be the screen. Have a check around the system and a little think through- them come back
Posted on Jul 10, 2007
  • john ash
    john ash Jul 10, 2007
    The the Data Cable - disconnect both ends and check the pints make sure you have none bent.
    If it is feasible take the display to another computer.
    This will prove -screen or computer.
    Then come back
Changing Resolution On A Fuji A350 Camera
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Dec 06, 2007 | Cameras
How take photo on archos gamepad2
Hi, the Gamepad 2 only has a front facing VGA (low res) camera. if you touch the 'all apps 6 dot icon, you ashould be able to see the x
camera icon. When you run it all of its controls are screen driven, the shutter (take photo) will be a circle with sporal lines on it. touch that and it will take a pic. it will take a picture of whatever is facing the screen si turn it round get below the screen out of shot, frame the pic and touch the shutter. Remember that its only VGA and has no flash so quality isnt great.
Sep 12, 2014 | Tablets & eReaders
My photos turn out "grainy" when I print them, no
Check your DPI settings, Dots Per Inch. The Higher the DPI the Less Grain you will see in the Photo but this is effected by the photo you are using as well. If your camera is set to a lower DPI setting it won't matter how high you set the DPI on the printer because the data isn't there for the printer to use. If you are using a program like Adobe or Flash or Gimp to draw or edit your photos make sure the photo or picture is being stored at the higher DPI setting. This will make the picture higher in total size. For example a picture stored at 24 bit color 300 DPI is about 1.2 mb in size. That same picture stored at 24 Bit color 1000 DPI is over 4mb when stored.
Feb 10, 2011 | HP Photosmart 3210 Printer
Recently, I have been experiencing trouble with my Nikon Coolpix P2. When I take photos, the picture comes out with faint white lines across them. The screen itself is fine, but once I press the shutter,...
Hello - from what you said - it sounds more like a sensor problem in the camera.
If the screen looks OK while sizing up a picture , then 'click' Image is stored on sensor which is read as one LARGE matrix of dots and stored into memory.
If the white lines start at this point - ie. viewing the picture while in camera and then after download.
Then, the problem started at the sensor.
I just did a (www.goggle.co.uk) and did a search for problems - and NONE apart from Wi-Fi connections to Windows7 -- all reviews were great.
I would connect Nikon to see what they recommend . -- Ray
Jan 23, 2011 | Nikon Coolpix P2 Digital Camera
Gambar kurang terang
Hello, P'Hendy
This can be caused by these things: 1. Bad Camera settings. Make sure to set picture quality to highest and set your flash correctly while take pictures ( or just set it in auto). 2. Bad The printer. Have you use good printer? I suggest you to use printer with capability up to 4800 dot per inch (dpi) 3. Bad ink and paper. You should use good quality ink and photo paper.
Nov 29, 2010 | Nikon COOLPIX S230 Digital Camera
TIDAK BISA TERANG HASIL CETAK GAMBARNYA
Hi, P'Hendy
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Unhappy with the quality of the pictures
Is the white dot in the viewfinder? I could see that getting very annoying so I'd probably send it back. The shots I've taken indoors with the flash on the c2100 have not had any problems with over exposure. There are both exposure and flash compensation settings in the camera, make sure you haven't changed them by accident. If this is your first digital you have to get used to the way the images look, it's not the same as film. At first digial images look "soft" and more grainy, more so if you look at them at 1:1. I usually view them so they are about 8" wide on the screen, or about 1:2. As the number of pixels goes up the difference between different compression levels becomes less noticable. If you shoot in 640x480 mode you'll see a difference between high and normal. At full resolution on some shots you'll get better color on SHQ over HQ. And TIFF is rarely any better than SHQ.
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Philips 170C4FS 17" LCD Monitor Logo
134 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
