Question about Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow
Vacum cliner not work, indikator green light
Akku ok put the swich only green led blinking
Neato seems to have died but the green light is on
Mine was doing same thing. was working flipped upside down to replace the rubber blades then nothing.Display dark only it has green led around orange button. Unplugging batteries didn't help.pressing buttons nothing. holding buttons down nothing. Found this on another site. Connect the vac to your computer and place it on charger at same time. Press and hold the orange button for about 10 sec. or so. it should turn of the LED then let up and repress button. vac should then reboot. Unplug computer. Wouldn't hurt at this time to tell it you put in "New Batteries" but first remove any scheduled cleaning days to clear its memory. After doing the New battery, reset the schedule and let it charge. After that it maybe a good time to check your program version and update it from the Neato web site to the newest update. The newest update does wonders for the battery run time issues.
Feb 07, 2014 | Neato XV11 Vacuum
Led light wont come on
When you remounted the freezer door you might have missed or damaged the switch (button) when you moved the unit. Check that and replace it if necessary. That should fix the problem.
Nov 14, 2013 | Electrolux Vacuums
The green light on my Kirby Ultimate G is not on but brush is spinning suction is pick stuff up. Is there a light bulb or a bigger problem?
You are referring to the green led light on the front of the machine that tells you the brush is rotating? this is operated by a small magnet on the brush roll, when rotating it generates a small current to bring the light on. Remove the brush roll and check for damage behind the green led inside the case, also check for the magnet on the brush roll, ensure it is not missing and the brush roll is in the correct way round, magnet needs to be at green led end (ie to the left)
Magnet is fitted flush within the brush roll close one end and is around 6mm 1/4" diameter.
Green light not working will not affect the machine in any way.
Sep 26, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Green light
Aug 29, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux Unirapido not working green light flashes when start button is pressed!
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Apr 15, 2013 | Vacuums
When the vacum is set on the bare floor mode, the on/off light blinks and the roller brushes stop working
This is normal. The roller brushes aren't needes on bare floors. They are used to brush lint, hair, etc. from the carpet that the suction itself wouldn't get.
Jan 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
How do I put the belt on the Kirby the correct way in order for the green light to come on? The green light indicates that the Kirby will pick up.
The G4 has a magnetic block on one end of the brush. It must be aligned on the LED end of the brush housing. ..with adjustment screws facing out. When setting the housing back in place use the pedal to lift the carpet nozzle up off the work surface
Sep 06, 2009 | Kirby G4 Bagged Upright Vacuum
I want dismont the rainbow vacum cliner to see the engine
Finaly, I find the screws and I desmont the vacum cleaner. Afther that I find in short circuit the rotor of the motor. Now I must fix the rotor.
That it.
Thankyou very much.
Leon NICA
Jan 10, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Electrolux Zb2803 Unirapido Rechargeable Stick Vacuum Cleaner, Fresh Yellow Logo
102 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
