Question about Scantron Office Equipment & Supplies
My Unit #2250 Scantron will not power on. I have switched cords and plug ins but it has not helped. Any ideas?
When I turn the piano on, nothing happens I checked the plug-in but still nothing happened. I just played the piano a couple of days ago and it was fine. Do they have fuses which need to be...
I woulld not even venture a guess as to what brand/model/ etc you have. How do you expect us to have any idea to help you?
I will say that a very common problem is if the unit, whatever type it is, has a power adapter, it is COMMON for the plug to work loose... If your unit has a regular cord, then there are likely fuse(s) inside, but if they blow, there is another problem that must be repaired before fuses are replaced.
Does the unit have any lights or displays that show power is on? If nothing is lit, then VERIFY that the cord is plugged in at both ends... ANOTHER problem is that SOME wall receptacles are switched... intended for floor lamps and if one has the switch off the receptacles is dead...
Again, you haven't given us enough info to really help you...
Nov 10, 2010 | Music
Every time i press my foot switch the motor are not running only you hear a little sound
Your power cord may have a loose wire, take it back to where you bought it and ask for service. If, it is Walmart or Target ask who does is the authorized service center
Aug 27, 2010 | Singer 2250 Tradition
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
My printer is showing error oxdo5do1od recycle power how can i over come that
Please perform the following steps:
Step 1: Power Cycle
1. “Shutdown” your computer.
2. Verify that the unit is switched ‘on’.Unplug the all-in-one from power and ‘disconnect’ the connection port.
3. Wait 30 seconds.
4. Plug-in only the ‘power cord’.
5. Repeat steps 2-4 two more times.
6. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
7. Restart your computer and check the functionality.
Step 2: Partial reset:
1. Unplug the power cord from the unit.
2. Press and hold # and 3 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit
If the issue persists, perform the following:
Step 3: Semi ful reset:
2. Press and hold # and 6 buttons together while plugging in the power cord back to the unit.
3. Turn on the unit.
If the issue persists, pleae conect the unit to a diffrent power out let. Also please chek if the unit works fine in the stand alone mode (with out connecting to the computer). If the issue persists, replace the printer
:) Dr Tony
Apr 19, 2010 | HP Officejet 5610 All-In-One InkJet...
I tried turning on my monitor and it wouldn't turn on. I checked the power cord and everything was connected correctly. Any Idea;s?
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Feb 10, 2010 | Mag Innovision InnoVision LT765 17" Flat...
Tower switch dose not turn on.i took out power wire from the wall plug when i went to trip 5 weeks ago
Make sure the power cord is securly plugged into the Power Supply Unit in the back of the PC and also in the wall outlet. Look for a switch by the cord plug on the pc that will have a straight line and a circle on it. Make sure it's switched to the ON position (straight line). Try and turn on your pc.
If this does not work still, try a different AC outlet on another wall or in another room. Also try a different power cord for the PC. If none of these work and your machine will still not start up or you don't hear any fans going when you press the button, it might be a bad Power Supply Unit (PSU). I have seen PSU's blow out just by plugging or unplugging the power cord because it can create a spark. If you have a bad PSU, you will need to contact someone local to replace it or you can take your unit to a Best Buy or local computer store and have them give you a price on a new PSU.
Dec 14, 2009 | Sony VAIO VGC-RB42G PC Desktop
99 Tiburon wont start.
first check to see if you have spark if you do try the cam sensor that tells you injectors when to work
Aug 20, 2009 | 2004 Hyundai Tiburon
I also have HP 6310xi all in one printer with power reset message
1. Please make sure that the power adapter is working properly. Also connect the unit to a different power outlet and verify.
If the issue persists, please perform the following steps:
Step 1: Power Reset:
1. Disconnect the unit from the computer. Verify that the unit is switched ‘on’. Unplug the power cord from the back of the unit.
2. Wait 30 seconds.
3. Plug-in only the ‘power cord’.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
If the issue persists, perform the following steps:
1. Take the cartridges out of the unit. Unplug the power cord from the unit.
3. Turn on the unit and insert the cartridges.
This will solve the problem...
Jun 23, 2009 | HP Officejet 6310 All-In-One InkJet...
Kirby Generation 3 no power...
I don't believe there are any service manuals online, as Kirby has service centers around the country. There are 3 things in the power string--on/off foot switch, the power cord, and the power assembly that the cord plugs into underneath the bag in the main part of the body. One of the problems the G3 had was where the cord plugged into the body--the assembly was a very thin plastic piece supporting the 2-prong electrical connection. This plastic piece was known for breaking, and was actually recalled back in the 90's. You can take the cord connection off and look to see if that piece is broken, then you'll have to take it in, or buy a "switch" as it's called on ebay or somewhere and replace.
Dec 29, 2008 | Kirby Generation 3 Bagged Upright Vacuum
How do i install an xbox360?
Plug the power unit into to the back. Plug the AV cable to the back of the TV (match the colors) and the back of the Xbox. You'll either use the red/white/yellow if you have a regular tv, or the red/green/blue if you have an HDTV. Then switch the switch on the AV cable to the right setting (HDMI/HDTV or regular TV). Install the AA alkaline batteries in the controller (or the battery pack if you got the rechargeable battery kit). Plug the power cord into the power unit, then last plug the power cord into the wall. Wait a minute for the power unit to light up and then push the big green Xbox button in the middle of the controller down for three seconds and let it go. It should turn on. If not, find someone local to help you. This is all stuff covered in detail in the owners manual.
Jan 01, 2008 | Microsoft Xbox 360 Console
Top Scantron Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Scantron Office Equipment and Supply Expert? Answer questions, earn points and help others
