Question about Hardware & Accessories
Where can I purchase pins for the mini I series batrow timer?
Controller will not respond to clock nor the manual setting
Remove batteries wait 10 min Clean battery terminals with metho
then try again sounds like corrission on battery terminals
Apr 03, 2014 | Garden
Looking to buy the red pin to set the sign timer
1) Timer is not identified.
Question posted under Intermatic T100 series which has metal trippers, and not green and red.
2) Copy following links to help identify timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Tork-timers-and-manuals.html
http://waterheatertimer.org/Paragon-timers-and-manuals.html
3) Add a comment Dec 2012 and describe timer in detail. Or attach a photo of the timer for possible identification.
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
If I knew what a "pin" looked like, I would be able to set the Model 59200 timer that I purchased just this morning (actually I purchased two). The instructions seem to assume that people are...
Woods 59200 has segments located around edge of timer dial, and Woods 59201 has pins.
Some manuals say pins, when they mean segments, and some manuals call segments pins.
Pins:
http://waterheatertimer.org/images/GE-mechanical-pins-1-200.jpg
Segments:
http://waterheatertimer.org/images/GE15107-004-2-166.jpg
The following link tries to sort out the pin-segment issue with illustrations:
http://waterheatertimer.org/How-to-set-timers.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
How to set my grasslin pool time trying to understand to let it run in day and shut off at nite about 6pm so i need to set it that way with the pin
Open following link for setting Intermatic/Grasslin FM1 timer setting instructions:
To set the 24-hour analog timer, you need to move 4 consecutive tripper pins for each hour of run time.
So for 6 am to 6 pm, 48 trippers pins will be moved outward and 48 inward.
http://waterheatertimer.org/pdf/How-to-set-Intermatic-FM1-timers.pdf
Open following link for Intermatic FM1 series and PB series modular timers with wiring, manuals, model numbers and instructions for setting.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
Add a comment for more help
Upvote the help.
Jun 08, 2011 | Intermatic FM1STUZH-120U - 24 Hour...
Where are the pins on the 59382 outdoor timer
The 'segment pins' mentioned in manual are tiny segments located around outer edge of dial.
There are 4 segments per each hour.
Each segment represents 15 minutes.
Use small screwdriver or fingernail to pull segment up.
When segment is up, timer is OFF
Leave segment down, timer is ON
Timer is 500 Watt.
Timer handles maximum 20 strings of 50 mini-bulb Christmas lights
Dec 06, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
LOST MY INSTRUCTIONS ..... HOW DO I SET THE TIMER?
You posted under Woods 59204 outdoor timer.
If this is not your timer, add a comment.
http://waterheatertimer.org/Woods-timers-and-manuals.html
manual for Woods 59204 timer
http://waterheatertimer.org/pdf/Woods-59204.pdf
Instructions:
Rotate dial until current time lines up with arrow.
48 segments (or pins) located around edge of dial > each segment is 1/2 hour
Set ON-off times by pushing pins in or out
Pins pushed out = timer ON
Pins pushed inward = timer OFF
Plug in timer.
Maximum 1250 Watts.
50 mini-bulb strand of Christmas lights is 25 Watts.
Timer will operate 50 strands of 50 mini-bulbs.
Long-winded guide for Christmas light wattage:
http://www.christmaslightsetc.com/pages/how-much-power.htm
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
How do you set on and off mode???
Tork, GE, Woods, Intermatic make a series of timers that have pins
The pins push out for OFF or ON times depending on brand
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
Need to purchase pins to place in the small daily timer of the ti
go to intermatic site
www.intermatic an search for irrigation timers. scroll to bottom of page and you'll see whats listed below
* Includes rain sensor input terminals- rain sensor not supplied.
** Includes 24 volt - 20 VA transformer.
For additional trippers (12 per pack), order No. 156T1950A.
For additional skipper pins (14 per pack), order No. 156T1954A.
Apr 04, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
77 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
