Question about Kenwood KSC-15 - 8 Hour Charger
On the Kenwood KSC-8A charger does the light blink when batt is fully charged
2 Suggested Answers
SOURCE: Kenwood KSC-WA801
You can use a computer power supply to run this sub on your home stereo system. I've got my one of these out of my car temporarily and I've hooked it up to my system to give it a bit of extra boost while it's spare! Use the yellow 12v lines of the power supply to attach to the +12v inputs and the black ground wire for the -12v. Works a treat, and even when blasting it, the power supply I use (250W) doesn't even get hot.
Posted on Jul 31, 2007
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger.
Best regards.
Jan 31, 2014 | Kenwood KSC-37 Replacement Charger for...
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
Kenwood KSC-37 why does red light blink
In the manual, it states that if the LED is Blinking Red "The battery pack is defective or the battery pack contacts
are not properly mated with those of the charger" Below is a link to the manual.
http://www.buytwowayradios.com/products/resources/Kenwood/KSC-37-Owners-Manual-1.pdf
Apr 04, 2013 | Kenwood KSC-37 Replacement Charger for...
When the walkie on full charge the charge light is not going to off ?
If your battery is flat or close to, then a complete charge is ussually 23 hours. or thereabout, so this is why the light on your charger is still on. The light for a flat battery is red and when the battery is fuuly charges light is green.
8 hours of charging a flat battery, isn't enough, hence the light staying on RED, if I'm not wrong and I doubt that I am.
I hope this has answered your query.
Best regards,
Peter
Oct 09, 2012 | Kenwood KSC-15 - 8 Hour Charger
I have a TK-280 and when i put it on the charger the red charging light comes on the starts flashing red after about a min. I am on the fire dept. where i live and kinda need it charged up. I wanted to...
  • Couple things this could be.
  1. First thing is to make sure the radio is seated properly in the charger and that all the contacts are making contact and not dirty.
  2. The other thing this could be is that the battery is bad. Or in the least the capacity for the battery is extremely bad and not reliable.
  3. If the contacts look good and it's sitting on the charger proper than you will need to get another battery pack. Sorry.
  • Hope this helps and thank you for using FixYa.
Regards, Tonyu
Jul 14, 2011 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
12v 1.5amp fully auto, alwyas worked, hook up to battery 12v 8.5amph, alwys red light flashed, went solid while charging, then off, or flashed, and off cause was already fully charged. now red light just...
I really don't have any idea as to what you're talking about here other than a battery and maybe a charger. Seems as if you're saying that you have a 12 volt 1.5 amp automatic battery charger connected to a 12 volt, 8.5amph battery but the red light on your charger is blinking. The blinking red light indicates that the charger is not seeing a proper connection such as crossed polarity connection or simply a poor connection. You say that the battery voltage has dropped from 12.5 volts to 9.1 volts with the charger connected. If this is the case, the battery is badly discharged and the charger is not charging the battery for some reason. The charger may be bad but check the connections to make certain they are correct and good. If they are, I'd replace the charger.
Good luck
Steve
Aug 10, 2010 | Harley Davidson FXR Super Glide...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My canon fs 100 doesn't turn on
I took the camera to the representative and we started various tests such as:
Tried My battery in OTHER camera .... not working
Tried OTHER battery in MY camera .... works
Tried charging MY battery in OTHER Camera .... works
Tried MY battery in MY camera and charged .... worked
Bottom end is that my charger is not working although it heats when "charging".
Now i will look at the pins in the charger to see if they are working or not.
Whatever the case .... getting a new charger.
May 29, 2009 | Canon FS100 Flash Media Camcorder
Kenwood KSC-15 - 8 Hour Charger Logo
99 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
