Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Electrolux Dishwasher 24 " not enough water new fill valve new float hot water Water lines clear. water too low float never rises amd the dishwasher runs water barly covers the top of the filter straner Model FDBB2455FS0
  • recoush Jan 24, 2009
    water pressure good. sprayed hose into sink before replacing valve.
    added 18 " loop upside of dishwasher then back down to drain from pump. maybe a little more water not much change (just_bobZ) seemed like a good idea. their seems to be a good flow. not sure what water pressure is to Dishwasher. timer seems to delay and allow water in. cycles a few times, doing a load now to see if dry soap dissolves. How much water should be in tub? water covers large screen but float not floating. water not across the tub just center of tub not touching the element.level
    Sergeant:
  • 311 Answers
If i was at your home as a repairman this is what i would do.if your water pressure was good at the kitchen sink,i would turn water off to dishwasher undo water connection at the fill valve,and place water line in a bucket and turn on water.if ok and still not getting water then prob with fill valve.soooo you have a new valve,did you check the water pressure to the valve? if yes good because then you also flushed out that in coming water line.because[and i have done this a few times]if not flushed their could have been minerals setting in that supply line so when you turn the water back on it pushes that stuff into the new water valve screen and blocks it up also.if your getting water then its trying to do its job,it just cant get enough water and the timer times out so no more voltage to the water valve.thats a lot said but there no mystery to it.the timer allows for lets say a 70 sec fill at 40 lbs water presure ,seventy seconds up that's it .the float only stops it from flooding,too much water.it dose not tell the machine that there is not enough! so because its letting in some water that tells me the float switch is closed[and it should be]leting the voltage to the water valve.the water valve has to let in enough water then.i know i mixed up words a bit but i hope this helps you understand whats happening.God bless ,if you need more advice you can email thru FixYa tom
Posted on Jan 24, 2009
  • Thomas Malailua
    Thomas Malailua Jan 24, 2009
    the water should be close to the crown where the spray arm attaches in the middle of the dishwasher.and you should hear a unbroken sound as the water is spraying th ru the spay arm.you can add water for testing purposes with a pitcher.also i had a thought, dose your drain hose have a good loop so the water is not just draining out by gravity.also if you haven't double checked the water valve fill screen for mineral blockage,i would if were i.
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
Does not fill with water.
follow this steps and fix it. God bless you
Water Inlet Valve
Float
Float Switch
Jul 08, 2013 | Thermador 24 in. DWHD64CS Stainless Steel...
Electrolux professional series not pumping water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
Dishwasher runs but gets no water...
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water will not fill the washer
Hi
Daniel
Jan 24, 2011 | Frigidaire 24 in. GSB5712BC Gallery...
Dishwasher not filling with water. Humming noise.
Hi
Daniel
Jan 08, 2011 | Bosch 24 in. SGS43C12 Classixx...
It won't fill with water. Water is valve is on.
Hi
Daniel
Dec 10, 2010 | Frigidaire 24 in. GLD2350RC Energy...
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Not filling
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Aug 20, 2010 | Electrolux 23 in. ESL624 Built-in...
Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Jun 08, 2006 | Whirlpool 24 in. GU1500XTLS Stainless...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
543 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
