Question about Nuance OmniPage Pro 18 Standard - 2889AGG418.0
OmniPage 18 ADF
Invalid ADF Command
We need to get the printer to recognize the network server name or IP address. At present it says "Unable to connect to (DC-260-795622). The server name or IP address may be invalid.
Ensure that all your network settings on the printer are correct, especially the DNS settings. Are you able to ping the printer from a workstation? Maybe you have a bad cable connecting the printer.
Jan 21, 2015 | Xerox Office Equipment & Supplies
MICROSOFT ERROR 1327 INVALID DRIVE E:\
  • Go to command prompt. Click on Run and type CMD and press ok.
  • In the command prompt type the command:
Syntax:
Subst (invalid drive letter): (existing drive letter):\
then hit enter
May 27, 2011 | HP Office Equipment & Supplies
When i download on ma phone, i get jar invalid command
The Invalid jar command is simply because you're downloading a java application not meant for your phone's version of the java software.
This is corrected by simply downloading Java applications meant for your phone, Thousands of which can be found at www.getjar.com
If you are absolutely sure that the Java applications you are downloading are designed for your specific device, You may have to try A) a master reset and/or B) upgrading the software/firmware of your device.
Hope that helps!
May 04, 2011 | Samsung GTC3300 Cell Phone
Invalid command, line 01 code 400
Mornach 9825 printer is error "Invalid Command! Line 01 Code 400 ".How issue this error.
Apr 16, 2011 | Monarch Paxar 9855 Printer
When loading for a scan on the top tray, it starts
Refer a web link for ADF cleaning
Step One: Refer a Web Document for ADF cleaning.
I am referring you to the necessary web document as it contains detailed steps with necessary text, hyperlinks and graphics:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01609880
NOTE: Clicking the link above may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
Step Two: Refer a Web link of Video: How to clean ADF.
I am referring you to the necessary web document as it contains detailed steps with necessary video, the printer model may varies from the original values, but the ADF mechanism is same in both model.
http://h30460.www3.hp.com/?rf=sitemap&fr_story=51aa0d07fcedc05e09901cb0daa93789d7f257aa&jumpid=reg_R1002_USEN
Feb 02, 2010 | HP OfficeJet 7410 All-In-One InkJet...
How to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Jan 06, 2010 | Brother MFC 6490CW InkJet Printer
Hp 3055 adf
Here's a link to the full service manual for your HP 3055. It's too large to post here (15MB) but I've hot linked it for you so you can download it to resolve your issue with the ADF. Look at pages 44 thru 46. Pay special attention to the rubber pad (separation pad) that is under the 2 roller peice as it is what keeps the doc feeder pulling one sheet at a time.
Hope that helps you. If so hit me with a FIXYA, If not send me a message or reply and I'll try and walk you through it.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/lj3050-3052-3055aio/Q6502_service_enww.pdf
Sep 02, 2008 | HP LaserJet 3055 All-In-One Printer
'mac address are invalid in both cmos and flash'
K, i hv a solution for u, first u need to download afudos utility from http://www.ami.com/support/downloadagreement.cfm?DLFile=support/downloads/amiflash.zip&InpDrvID=90. And then go to DOS mode, n type command like,
D:\...........\afudos /mxxxxxxxxxxxx
There is /m is the command n 12 times x is ur mac ID. N u can find ur MAC on some were on ur MB.
I think this will fix ur problem.
May 16, 2008 | Asrock 775VM800 Motherboard
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Invalid Command
Your 287 error has to do with an incorrect setting for printhead width, and in the control language that your software is sending to the printer, they either have something other than 0, or there is an invalid character like a carriage return or line feed being sent to the printer.
This is a difficult one to trace since the software sends the code and you cannot necessarily change what is being sent.
Please note that the software that you really should be using is PC Mate Plus, as this is a specialized printer for Paxar supplies called Care Labels. You may be able to cheat if your software allows you to select 300DPI print heads. If not, you'll need the software I suggest.
If you do not have this software, please contact Paxar (now Avery Dennison) at 1-800-543-6650 and ask to be connected to someone in technical support or if the customer service rep can offer you a link to a website for software download, or purchase.
Ohiotech
Nov 19, 2007 | Monarch 9855 Thermal Printer
Nuance OmniPage Pro 18 Standard - 2889AGG418.0 Logo
43 people viewed this question
Top Nuance Computers & Internet Experts
tony wahlman
tony wahlman
 Grubhead
Grubhead
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
