Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
I am looking for this part electronic control unit vcc 1156 01 F 41EG
THE model of the refrigerator is GSL 25 jFXLLB SERIAL NUMBER VS203741
3 Suggested Answers
kvhappliance
  • 218 Answers
SOURCE: brought the GE WR55X10942 Refrigerator
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Posted on Jul 15, 2011
imufo2
  • 3773 Answers
SOURCE: Model gsl 25 jfte bs Will
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 20, 2011
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
I need a compressor electronic control unit for Electrolux fridge with number VCC3 2456 56 F 71. Please replay. Thanks
Hello friend, thank you for your post!
Based off my understanding you need the compressor electronic control for your Electrolux refrigerator. If you could please provide me with your model number I would be able to assist you further. You can locate your serial tag (which lists your model number) on the inside right hand wall of your refrigerator usually on a silver or white tag. With that information I can better assist you. -Matt
May 26, 2015 | Electrolux Refrigerators
How to find serial #
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You do not need a serial number. The serial number is only specific to that unit.
Go into the following web site. Type in your model numbers above. You will get a list of 24 refrigerators that start with those numbers.
The 24 in the number means your unit is 24 cubic foot.
http://www.searspartsdirect/
Mar 05, 2015 | GE Refrigerators
OUR RFA4287HSAWP Samsung has the same problem mentioned here. It suddenly stopped dispensing ice with only water dispensing from both levers. I tried the ooparts number listed but of course was told i
If you can, send me the model and serial number from your unit... you can also snap a picture of the model/serial tag and please send it to me and i will help you solve this issue... the picture will give me a heads up to any updates for your unit... I think we are looking at a control issue but i want to be sure..... Ken Hawk...... Samsung support
Feb 12, 2015 | Samsung RF265AA Bottom Freezer French Door...
How old is my magic chef refrigerators, model number is CTB1720ARA, the serial number is 12318831UQ
I looked up this serial number and found that your unit was produced on Monday, May 02, 1983. I hope this helps
Sep 26, 2014 | Refrigerators
Need to replace door gaskets
Emmie,
There are two gasket options for that model! If you have your unit's serial # we can ID the exact gasket you need. Replacing your gasket is a simple process and it looks that your gasket is a simple snap in option. Here's option1 http://www.coolergaskets.com/turbo-air-gasket-25-1-2-x-53-1-4-1/ & Here's option 2 http://www.coolergaskets.com/turbo-air-gasket-25-1-4-x-53-1-4/
It looks like both gasket options are made out of the same profile material but the dimensions changed per when the unit was manufactured. Double check your existing gasket's dimensions to determine which option is the best for you. Or shoot us an email or give us a call with your Model and Serial # and we can narrow it down for you.
855-288-2259
orders@coolergaskets.com
Aug 03, 2012 | Turbo Air TSR-49SD Stainless Steel...
I have a Whirlpool side -by- side 25 cu.ft. want to know about what age it is?
Hi.
It depends on the model number. Whirlpool started building 25 cu.ft over ten years ago and the model is still being produced. Please find the serial and number printed on the refrigerator service tag and give us the complete model number along with serial number. The model number will tell us the initial date of production, the serial number tells us the date of production of the specific unit. Here whirlpool date codes explained. To find the service tag check in locations illustrated below.
Aug 19, 2011 | Refrigerators
The fan motor started making a sqealing sound about two weeks ago. Then noticed a burning smell this morning. Checked it again this afternoon and the plastic divider between the fridge and freezer is so...
you indeed do have a bad condenso rfan motor.. its the fan by the compressor behind the unit,,i couldnt find your model number on my part look up, but you can call samsung direct( cust service line) and with the entire model and serial number they will be able to determine the correct part number, you want entire condensor fan assy with housing and fan blade... it will come complte, you will simply unplug and snap in the new unit housing and all.. inn meantime i would pull unit away form wall and with a desk top fan orwindow fan blow it on te compressor to keep it cool you dont want to overheat the compressor. the youll have major problems
Oct 09, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
