Question about Amana Heating & Cooling
Fault code F1 Amana
MN:PTH093E35AxxxAB
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
Amana ACF 4215A
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn’t high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn’t happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you’re gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel –don’t spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Aug 30, 2008 | Amana ACS7270AS Electric Kitchen Range
Im getting F1 in my Amana Big plus oven
he "F1" fault code indicates an error in the electronic oven control circuitry. The failure is most likely the electronic oven control board and a slight possibility of a faulty oven temperature sensor probe.
Jan 26, 2011 | Ovens
My amana oven wont come on and show f1
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
!@#W
Aug 20, 2010 | Amana ACS7270AS Electric Kitchen Range
I have gotten the F1 code
HI. This code is in reference to the on-board electronic control board. This is a basic watchdog fault(relay failure). The necessary actions are to replace the ERC(main board). Replacing the board will correct this issue.
Jul 01, 2010 | Amana ACF4215 Electric Kitchen Range
Range Beeps and shows a F1 code in display. How do I fix this? Where could i buy the parts? It might be the membrane switch. Is this easy to replace?
Mar 14, 2010 | Amana AGDS902 Gas Kitchen Range
F1 error message flashing
$#%$ET
Dec 21, 2009 | Amana ACS7270AS Electric Kitchen Range
My stove has F1 in the display and won't let me set the oven temp
Oct 28, 2009 | Amana AER5515QA Electric Kitchen Range
F1 code
Mar 21, 2009 | Amana ACF4225AS Electric Kitchen Range
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
