Question about Hardware & Accessories
Vista dtc-150 digital electronic timer - Hardware & Accessories
2 Suggested Answers
SOURCE: how do I reset my
Open following link to identify timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Hamilton
The reset button is small round button with R
I assume you push reset button with toothpick
The manual is unclear if you need to press another button at same time to reset timer
Manual says: If needed, pressing "R" will cancel the current setting,
pressing "R" a second time will undo the change.
Posted on Mar 27, 2011
My Pontiac vibe 2006 is showing PO6006, PO6007 code does anyone ha be any idea what it means
P0606 , P0607 ! no such codes P06006 or P06007
DTC P0601, P0602, P0603, P0604, P0605, P0606, P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610
DTC P0606 Control Module Internal Performance
The DTC P0606 and P2610 set when the powertrain control module (PCM) has determined that the control module has an internal fault. The PCM performs continuous self checks of all internal circuits. There are 2 central processing units (CPU) within the control module. If the outputs from the two CPUs deviates from the standard level, a DTC P0606 sets. The control module has several internal clock or timer circuits. The DTC P2610 diagnostic monitors the internal timer circuit responsible for the ignition OFF operation of the evaporative emission (EVAP) system vacuum leak pump. If the there is an error in the control module timer, a DTC P2610 sets.
Feb 25, 2016 | 2006 Pontiac Vibe
All brake lights and traction light Or on the dash and my brake lights will not work 2006 Cadillac CTS
The traction control system is part of ABS control module an if the light is on there is A DTC - diagnostic trouble code stored in the EBCM - electronic brake control module ! The brake pedal position sensor is an input to the EBCM , when you press the brake pedal the EBCM then energizes the BAS relay in the left rear fuse box turning on the brake lamps !
There could be a DTC like
DTC B3903
The electronic brake control module (EBCM) supplies voltage to the BAS relay coil side voltage supply circuit when the stop lamps are active. The coil side control circuit of the BASS relay is permanently grounded at G402.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B3903 Stop Lamp Relay Circuit
Or
DTC C0278
The brake pedal position sensor (BPP) is a potentiometer. The electronic brake control module (EBCM) supplies a 5-volt reference circuit and low reference circuit to the BPP sensor. The BPP sensor signal circuit is a direct input to the EBCM. The EBCM determines the BPP based on the voltage from the BPP sensor. The EBCM converts the BPP sensor feed back voltage to a digital signal and puts it on the class 2 communication bus.
DTC C0282 Brake Pedal Position Sensor Circuit Range/Performance
DTC C0283 Brake Pedal Position Sensor Circuit Low
DTC C0284 Brake Pedal Position Sensor Circuit High
DTC C0880 Device Voltage Reference Output 2 Circuit
You may want to take this to the dealer !
Jul 14, 2015 | Cadillac Cars & Trucks
SA 150 20 MP TIMER--- I have a manual timer in place now which does not always shut off. It is wired in with Black and Red wires and green to ground. The diagram on this new unit is confusing me Help...
Open following link to identify SA150 single pole 15-minute countdown timer rated for 1 Hp
http://waterheatertimer.org/Sylvania-timers-and-manuals.html#countdown
Timer has 3 wires:
Timer-Black wire connects to Hot from breaker. One of the old switch wires is Hot. Hot is usually black wire, and will test for 120V when tested to ground wire.
Timer-Blue wire connects to Load wire going to light/fan/motor. The Load wire is other wire that connects to old switch.
Timer-White wire connects to white Neutral wires. This will power the timer electronics. Neutral wires are the white wires that are twisted together and covered with wire nut and pushed to back of box.
If box does not have Neutral wires, then connect Timer-white to bare ground wire until you have time to bring neutral wire to box from any nearby outlet. Wiring timer to ground in this manner is not code.
Turn power on. If timer does not work, then reverse Timer-Blue and Timer-black and see if timer functions correctly.
If Sylvania timer will not function, then call 888-548-4484
If you want electronic countdown timer that requires no neutral wire, then select 1 Hp spring-wound timer, or 1/6 Hp Leviton-LTT series
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 22, 2011 | Solar Sylvania Sa 155 60min Digital Auto...
I bought the ge digital heavy duty timer Model#15079 I want to use it for my saltwater tank where a light stays on from 7 am to 9 pm an another light stays on from 2 pm until 8pm is this possible with this...
Easiest solution is to buy two separate timers.
GE does not have 2 channel plug-in timer. Nor does Woods, UPM, Swilight, Sylvania, Tork, etc etc.
http://waterheatertimer.org/GE-timers-and-manuals.html
Zilla has a two channel power strip where one channel is for 12 daytime hours and 1 channel for 12 nighttime hours. The yellow outlets power daytime hours and blue for nighttime. You can adjust current time so the hours can be whatever, but the 2 channels are strictly 12 hours each and do not overlap
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Your time schedule doesn't fit zilla
You need a 2-channel timer which takes you into more expensive territory ($150-$300), or just buy two separate timers since each load has to operate independently.
Intermatic make 2 and 4 channel timer:
http://www.intermatic.com/products/timers/electronic%20time%20switches/7-day%20electronic%20time%20switch.aspx
Apr 13, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
Resetting the timer for Auto
I do not know how to 'reset timer for auto'
Manual says: "ON/AUTO/OFF" override. Press "ON/AUTO/OFF" or the
button with the "HAND" symbol to force the timer into permanent
"ON" "AUTO" program or permanent "OFF" mode.'
When within the programmed window (preset time period),
cycle through "ON/AUTO/OFF" button to "ON" mode
(indicated by lighted red LED above display), and then
"AUTO"
I have not tested this timer, but the manual sounds vague and confusing, leading me to believe you have to tinker around with the buttons and settings to make sense.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 26, 2011 | Vista Pro Digital 7-day Electronic Timer...
How do I reset my DTC Digital Timer for the Vista Outdoor Lighting sytem?
My dell was crashed so i used an old software from toshiba vista pro first it was xp but it ask for validationcode or product key,how can i get a legal productkey without payin or pay,afterwards while i...
You posted under Vista Pro digital timer, so request for free information arrives in hardware department:
For others who might click on this thread wanting free information about Vista Pro timer, open following link to identify timer and download same manual.
If you are asking about free software for your computer, please re-post another question at fixya.
Post question under software, or computers, or related, so correct expert can view question.
Another option: Call Toshiba or call Dell tech support and pay them to say you need to buy software unless you visit sites that offer pirated software.
Add a comment for more free help.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Vista Pro Digital 7-day Electronic Timer...
Cannot set the current time on a new DTC 170 vistapro timer
go to the follwoing link.
the spec sheet has the instruction how to set the time.
http://www.vistapro.com/Files/Specs/DTC-170-spec.pdf
Apr 06, 2009 | Hardware & Accessories
Hardware & Accessories Logo
74 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
