Question about Refrigerators
Freezer handle
Dear Sir, I have CAMPOMATIC UPRIGHT FREEZER MODEL NO FRZ 307 its handle is broke can you pleases give quotation of the same how will be delivered to us we are in DUBAI MARINA @ apartment no. 1603, Tower 1 DUBAI MARINA (UAE) above CHOI TRAM SUPER MARKET MY mobile nos is 055 9776846 and 0556364239 e mail : merchant786@hotmail.com will wait for your call or reply mail thanks saleem
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
steve6375
  • 395 Answers
SOURCE: need driver vga soft for vista
go to http://www.nvidia.com/Download/index.aspx?lang=en-us
and download and install the correct driver
Do you have 32-bit Vista or 64-bit Vista?
Posted on Aug 17, 2008
SOURCE: service centre in gurgaon NCR for brother all-in-one DCP 110C printer
Please give me HP authorised service center address/telephone nbrs in Gurgaon-preferably in DLF area if available
Posted on Sep 09, 2008
Fixe_You
  • 1800 Answers
SOURCE: no network signals in nokia 2630
look Mr Neeraj.
First i need u to restore the settings of the phone.
check the following:
Menu>Settings>Restore Settings
The Default Security Code is 12345
if thas is not helping u:
this problem Occurs when the PIF Chip its a amplificator Chip that amplifies the signal when the antenna catch it ..
u need to replace that part. (take it to a trusted* phone repair man cuz its not an eszay task at all)
i reapeat u shud perform the pervious in case if the ressiting process not help.
plz do rate this post as good as u can .
so we can help others.
*some of the phone repair mans take parts from phone so watch out.
Posted on Oct 09, 2008
aborcass
  • 2651 Answers
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Posted on Feb 13, 2009
How do we raise the temperature in our fridge and freezer?
Well, you didn't leave a model number, so I'll just give you the generic answer: If you keep pressing the Frz or Ref temp buttons, the temperature will cycle down to the lower limit and then pop back up to the upper limit and then repeat all over again. If not, look for up/down buttons, or +/- buttons.
Oct 21, 2014 | Refrigerators
Temp on upper is getting colder while freezer on bottom is getting warmer
Sounds like bad settings. Sometimes, the temp setting(sensed in ref area) controls runtime, and the frz setting adjusts a vent whuch passes air from frz to ref area. try raising frz setting.
Nov 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Compressor not running - food starting to thaw - older model 14.6 c/f upright model
dear sir/madam
please check the thermostat setting and make sure this thermostat device is working if it,s good and working then please check the compressor relay device and all electrical connections.
and contact to your service technician , for further maintenance.
hope answer the question
thank you
please vote!
Aug 29, 2010 | Whirlpool 16.7 cu. ft. Upright Freezer...
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
thank you
please vote!
Aug 23, 2010 | Kenmore 13.7 cu. ft. Upright Freezer 26442
Freezer does not freeze, only top two freezer elements seem to be working but poorly.
dear sir /madam
i think in your freezer have low gas problem please contact to freezer maintenance personnel for refill the gas after that it will good.
thank you
please vote!
Aug 14, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
No cooling. hot side and top.
dear sir/madam
i think there is low gas problem in your freezer so please contact to your freezer maintenance personnel for further action i mean find out leakage and make brazing it and then refill gas.
i hope after that your freezer will work well.
thank you
hope answer th question
please vote!
Aug 10, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
After moving, the freezer won't turn on
dear sir /madam
i think after 10 hour journy its main supply cord (electricity) or cable has been remove from its male type plug or inside of control panel so please try to contect to your feezer maintenance personnel for reconnect it.
thank you
hope answer the question.
please vote!
Jul 19, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
We have an E388 upright freezer...motor is still running but fan inside freezer has stopped working and freezer does not freeze..Any reason ?
dear sir/madam
i think your freezer,s indside motor is faulty so its not rotating motor is not working so freezer ,s evorator cycle is not having complete its reson for not cooling .
please contect to your freezer maintenance personnel for further action
thank you.
please vote!
Jul 15, 2010 | Fisher Freezers
Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
thank you.
Jul 05, 2010 | Frigidaire Freezers
Frigerator not working
2 possible issues. freezer fan is not working ,should be able to hear it inside frz.2nd issue auto defrost is not working, look for ice/frost build up on rear wall of frz.possible timer or heater issue Hope this helps ,pleases rate my response :)
Jun 25, 2009 | Jenn-Air Jenn Air Side-By-Side...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
