Question about Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard not working
The wireless mouse is working fine. However, the keyboard is not. The Bluetooth indicator can be blinking. Batteries are fine. Cannot get into the computer as I cannot type password to log in.
  • justyoung05 Jan 24, 2009
    Thanks. I am using Vista and was able to log into the computer using the onscreen keyboard, but I do not know how to reconnect the keyboard. I loaded the keyboad and mouse drive (SetPoint), but when I tried to check "device connection status", nothing comes up.
What o/s are you using? If Vista(and your mouse works) you can access the onscreen keyboard to log into your computer and access the utility to reconnect your keyboard.
Posted on Jan 24, 2009
My bluetooth mouse used to connect but now it doesn't...When I press the blue button, the blue light does not blink like it used to. Is my bluetooth mouse dead? (fresh batteries, and it turns on).
Mostlikely you need to repair the mouse with the computer. open your bluetooth utility or the keyboard/mouse utility and follow the pairing instructions. this should solve your problem
Feb 12, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
Jun 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell Bluetooth Wireless Keyboard doesn't work Mouse works fine. I have 2 Dell Inspiron 530's both worked fine for a few months then both got solid Purple status indicator light on keyboard. Instructions...
check the device for a " reset " button, they are usually located on the bottom of the device, if this does not work, you may need to contact dell directly and discuss the problem further.
Jun 21, 2009 | Dell Inspiron 530 Desktop Computer...
Bluetooth keyboard and mouse stopped responding on Dell Dimension E520
try to insert another usb drive on the port.it the usb works then probably the bluetooth transmitter is faulty. If the USB drive also does not work... then probably the USB port of the computer damaged.
Jan 15, 2018 | Dell Wireless Keyboard Optical Mouse w0147
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Trying to get a Logitec Keyboard and wireless mouse to work on D6
Hi
check it your bluetooth device connecter your loptop and go to the control panel --> add hardware wizard click next it will show the all hardware drivers in your loptop select your wireless mouse than click it.
it will work good.. and one power button is there please press the button it will show one blink  ofter you will check it..
Nov 16, 2008 | Dell Latitude D600 Notebook
Wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
Oct 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell bluetooth keyboard/mouse bundle
i just got the bluetooth keyboard and mouse but i dont know how to get them to work. can any body help?
Jun 06, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Installing a French ( Brand is Genius) keyboard to my Dell computer.
Pair to a Bluetooth Device (new and re-pair)
  1. Locate the Bluetooth icon in the lower-right corner of the computer screen, and compare the status to Table 1.
    (The Bluetooth icon may be hidden, click the Show hidden icons arrow to show any hidden icons.)
    Bluetooth Icon Status Enabled - The Bluetooth adapter is ready to pair with another Bluetooth device.
    Connected - The Bluetooth adapter is already connected to a Bluetooth device (if the desired device is not the one its connected to, it will have to be re-paired). Disabled - The wireless switch is off. For information on how to turn the wireless switch on refer to the
    Online User's Guide. None When no icon shows the Bluetooth driver needs to be installed, refer to Dell Knowledge Base Article:
    "How to Download and Install the Latest Dell Wireless Bluetooth Driver" Table 1: Bluetooth status
  2. Verify the following conditions have been met:
    • Batteries are Installed in the Mouse and Keyboard.
    • The Bluetooth adapter, USB Bluetooth adapter or 13/19-in-1 Media Card Reader is installed in or attached to the computer.
    • The latest version of Dell Bluetooth Wireless Keyboard and Mouse Bundle is installed,
      if unsure refer to Dell Knowledge Base Article: "How to Download and Install a Driver"
    • The Bluetooth device you are going to pair is within 30 ft. (10 meters) of the computer.
  3. Right-click the Bluetooth icon in the system tray.
  4. Click Add a Bluetooth Device.
  5. Turn on the Bluetooth mouse and press the Bluetooth connect button on the bottom of the mouse. The Bluetooth LED on top of the mouse should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  6. Click Next to start searching.
  7. Click the icon for the mouse to highlight it and then click Next.
  8. The connection is set up automatically. Once the connection to the mouse has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the mouse indicates it is connected.
  9. SetPoint will now launch and ask to check for updates, click OK. If an update is available click to download it.
  10. After the update has been applied, click OK.
  11. Turn on the Bluetooth keyboard and press the Bluetooth connect button on the bottom of the keyboard. The Bluetooth LED on top of the keyboard should start blinking. If the LED does not blink, press the Bluetooth connection button again and hold it down for 2-3 seconds until the Bluetooth LED starts blinking.
  12. Click the box next to My device is set up and ready to be found and then click Next to start searching.
  13. Click the icon for the keyboard you want to connect to in order to highlight it and then click Next.
  14. When the keyboard is connected, the Confirm Keyboard Connection screen appears. A passkey that has been generated for the keyboard is shown. Type in the passkey as it is shown on the screen. Note:
    The keyboard can only store one passkey. The passkey is unique to each computer. If you try to connect the keyboard to more than one computer, the passkey is changed each time you create a connection.
  15. The connection is set up automatically. Once the connection to the keyboard has been created, the wizard closes and returns to the Bluetooth Settings window. The new connection is now listed there. The link symbol under the keyboard indicates it is connected. You are now be able to use the devices.
Aug 25, 2017 | Trust Silverline Direct Access 12879...
Logitech wireless mouse
WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables.
Sep 15, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard Optical Mouse w0147 Logo
296 people viewed this question
Alun Cox
