Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Freezer making noise
Non stop roaring noise intermitently
MY KENMORE UPRIGHT 20.6 CF FREEZER IS MAKING HARMONIC METALLIC BUZZING NOISES. I TRACED THE SOUND TO THE MIDDLE OF THE BACK PANEL. SEEMS LIKE A METAL FREON HOSE OR SOMETHING IS VIBRATING AND HITTING THAT BACK PANEL, BECAUSE IF I PRESS ON THE BACK PANEL THE SOUND GETS WORSE.
MAYBE A MOTOR IS BEHIND THE PANEL, BUT THERE IS NO WAY TO REMOVE IT AND FIND OUT SINCE IT IS PLACED IN A LIP MADE BY THE SIDES AND TOP, AND THEN FOAM OF SOME SORT IS FORCED INTO A SMALL HOLE TAPED OVER IN THE BACK. TO FILL THE SPACE OR INSULATE. HOW CAN I FIX IT? I DON'T THINK I CAN, BUT AT LEAST I KNOW WHERE IT IS COMING FROM.
Posted on Feb 06, 2009
My upright Frigidaire freezer stopped running. I have checked the outlet and it functions just fine. The light doesn't come on, no controls work makes no noises. Acts like there is no power to...
Hello Ed Greene, thank you for your inquiry!
I see that your Frigidaire freezer is not operating. You explained that the outlet is working and the lights or controls are non-operational. It sounds like a potential issue with the power cord or control panel within your freezer. It would be best to have a technician come out to the home to review the freezer to diagnosis the correct problem and replace parts as necessary. This will help avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Dec 12, 2014 | Frigidaire Freezers
NEW freezer making a singing/high pitched noise
That will be the expansion of the coolant turning back into gas and perfectly normal.
Nov 11, 2014 | Frigidaire Freezers
I have had my freezer for a couple of years and probably only used it 6 times. The motor makles a roaring noise and sparks are coming out of it? Any idea what it might be. I checke the price of a new...
My 6 qt electric was making noise and finally quit spinning. I pulled it apart and the change gear (gear reducer) was wallowed out. This meant the gear rocked away from the motor's drive gear. I called White Mountain to see if I could get a replacement gear and they said I'd voided the warranty because I took the 3 screws out to pull apart. Basically, they are using **** gears, know it, and doing the song and dance to not have to replace. So, I've got a motor that works, housing, and one bad gear that makes the whole unit worthless.
Aug 10, 2011 | White Mountain Freezer F69206-X 6 quart...
Whirlpool freezer which is non frost is making ice and freezer stop working
I would first unplug the freezer, let it thaw, and then plug it in to see if the motor kicks in. If that is to no avail, then you could be looking at a bad motor.
Mar 09, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
My Viking Freezer is three years old. The problem is the constant roaring sound it makes. No one can sit in my kitchen, family room or living room for very long before the noise from this freezer gets on...
There are several fans on your unit one on the top with the compressors, one inside the freezer, and one at the bottom. If you open the freezer and the noise gets louder or stops then you know it is the evaperater fan. Sometimes the bearings start to go and they make louder noise. Also check on the back wall for frost you could have a frosting problem and the fan blade is hitting on the ice
Oct 23, 2017 | Viking 15.9 cu. ft. Upright Freezer...
Freezer stopped working.
It might be the compressor making the noise.If it is,the compressor will start/stop frequently.This means that it is tripping on overload due to mechanical damage.Only way to solve this prolem is to replace the compressor (if the freezer is still in a good condition).
Regards
Andre Nagel
Mar 25, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Freezers Logo
396 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
