Question about IBM Infoprint 1532 Express Laser Printer
982 service engine comm
Mp 2000 sc 982
i'm guessing == Scan, Color
Jan 03, 2015 | Ricoh Aficio Mp 2000 Copy Machine
I have a 5 year old Midea aw60-982 washing
Sounds like a bad belt or a locked up pump.
Sep 16, 2013 | Washing Machines
982 cub cadet 3 blade w/ idler pulley deck belt diagram
hi there pauly 46 here
here is web site for streetsign cub cadet 982 46 " deck with 3 blades
http://www.partstree.com/parts/?lc=cub_cadet&mn=336+46%22+Mower+Super+Garden+Tractor&dn=0057000002
this shows deck belt routing
and here is website area for 982 parts break down for model 982 cub cadet
http://www.partstree.com/parts/?lc=cub_cadet&mn=982
take a look cheers hope it helps
pauly46
Apr 28, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Error occured sc:982 Please help
SC: 982 Localization error
Symptom: The localization settings in the nonvolatile ROM and RAM are different (SP5807).
Possible Cause:
- First machine start after the NVRAM is replaced
- Incorrect localization setting
- NVRAM defective
Feb 02, 2011 | Ricoh Aficio MP 2000 Black and White...
Hi..where can i download repair manual for lancer GLXi 2005
Hi,you can download the manual for your mitsubishi at www.manualsonline.com,www.manualnguide.com and www.mitsubishi.com. please don't forget to rate this solution positively Thanks and good luck
Apr 19, 2010 | 2005 Mitsubishi Lancer
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Aug 02, 2009 | HP LaserJet 3050 All-In-One Printer
982 Service Engine
This is caused by an option on the printer not be seated correctly or there's a prob. with 2000-sheet feeder option.
Usual Cause:
  1. Reset power or power the printer off and on.
  2. If this does not resolve the error:
  3. Power the printer off.
  4. Reseat all of the paper feed options on the printer:
    • Remove all optional drawer options, like a tray 2 or tray 3 drawer, and reposition them from the bottom up.
    • Reseat the printer on top of the duplex option, if one is installed.
    • Reseat other options such as the envelope feeder or additional output bins.
2000-sheet feeder option? See below:
Explanation of the Issue
A cable can come loose inside the 2000-sheet feeder option and cause one of the following three conditions to occur:
  • The printer displays a 982.xx error. NOTE: The .xx extension can be any number.
  • The printer displays a 990.xx error. NOTE: The .xx extension can be any number.
  • The printer does not recognize the 2000-sheet feeder option installed.
The issue is with a toroid on one of the cables (see the blue/black wire cable highlighted in the image below). When the 2000-sheet feeder option is moved, the toroid can pull the cable loose, causing an error. NOTE: This toroid was removed in later versions of the 2000-sheet feeder.
Jun 11, 2009 | Lexmark T644 Laser Printer
Engine comm error
reconnect your usb cable to printer to computer.then also try tochange that usb cable if pro remains.
Feb 09, 2009 | HP Color LaserJet 2600n Printer
Denon AVR-982
I tryed to look up this model but didnt find it??? HMM ok the optical inputs are sensitive and were you using them?? and then they went out or have they ever worked??? I would open the unit to see if there is a plug or cable disconnected or loose on the input PCB. If that dosent help you probably have a b+ feed issue as all three use the same b+.. your gonna need to contact the manufacturer for service or viset an authorized repair center unless you can get a schematic and trouble shoot it yourself.. Contact www.contactservice@denonnj.com Good Luck
Apr 30, 2006 | Denon AVR-982 Receiver
IBM Infoprint 1532 Express Laser Printer Logo
29 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
CheckitRight
CheckitRight
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
