Question about Kenmore 24032\24036 Top Load Washer
Agitator not turning during cycle
My Kenmore washing machine Model 110.92581200 My agitator doesn't work during the agitate cycle. The basket spins during the spin cycle. The water level and timer controls continue to work correctly. The agitator dogs are OK. I understand that there is a motor ""gear"" that should connect and start the agitator. How do I find and identify this and check if that's the problem. Is there anything else I should check?
  • 1 more comment
  • Art Williams Jul 12, 2007
    I checked the agitator and the grooves are fine. I did not see any oil under gear case but feel that it's the only part left that makes the agitator work. Do I just replace the gear case or is there another way to check if that's the problem.
    Thanks for your clear comments.
  • Art Williams Jul 13, 2007
    I sure can't say what fixed my washer, but after trying and probing from all the great suggestions it just started to agitate again. I'm sure there is still a problem but for now I have a working machine.
    Thanks again to all that gave great and valuable advice.
  • Anonymous Mar 21, 2014
    it cycles but doesnt spin or agitate
  • 5,911 Answers
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Posted on Jul 10, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 13, 2007
    The gear case is a likely suspect, but you may have a basket drive causing you problems too. The basket drive is what the gear case shaft inserts into under the agitator. It can be a real bear to replace, however. I don't have an easy solution as far as how to prove the gear case, or the basket drive, because they both can exhibit the same symptoms. In some circumstances replacing both may be required. If you go the route of replacing the basket drive you should also replace the upper and lower drum seals (one fits in the agitator shaft and one fits under the basket) along with a spanner nut (which holds the inner basket in place under the agitator). The reason being that these components can be damaged while trying to remove the basket drive. The gear case is generally a simple matter of removing the water pump, drive motor, agitator and four bolts and it drops out from the bottom of the machine. It's less work, but may be more expensive. So...I don't have an easy fix for you. Drive problems are usually a maintenance intensive endeavor. I hope this helps some.
2 Suggested Answers
SOURCE:
CompuGuy44
  • 432 Answers
SOURCE: No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Posted on Jul 07, 2007
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
No agitator action
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,581 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
