Question about HP Compaq d530 SFF PC Desktop
Rom battery replace - HP Compaq d530 SFF PC Desktop
  • HP Master
  • 7,627 Answers
If you are refering to the CMOS battery, Open the case, look for a button battery, remove and replace. Take a look at HP support: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph04375&lc=en&cc=us&product=94878
Posted on Jan 16, 2013
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
My CD rom is not working
No matter what type of laptop you own or how you use it, the CD-ROM or DVD drive is an important part of the unit. With the CD or DVD drive in place, you can play your favorite music or watch your favorite movies, so when that CD or DVD player stops working it is important to get it back in service as soon as possible.
1.Locate the bypass hole on the CD-ROM drive. There is a very small hole, generally located underneath the eject button, on every CD-ROM drive. Unbend a paper clip and insert it into the hole until the CD tray pops out.
2.Remove any CD that is in the tray and replace it with a CD laser lens cleaner. These laser lens cleaners are available at computer shops and electronics retailers.
3.Run the laser lens cleaning program, then try to play a CD again. If that CD fails to play, replace it with another CD and try again.
4.Shut the computer down and remove the AC power cord if cleaning the laser lens does not resolve the issue. Turn the laptop upside down and slide the battery release lever to the unlocked position.
5.Remove the battery and set it aside. Then locate the screws that hold the CD-ROM drive in place and remove those screws. Slide the CD-ROM drive out of the bay, then slide it back into the bay until it snaps securely into place. Replace the screws that hold the drive in place, turn the laptop back on and try to read the CD again.
6.Log on to your computer and right click on the "My Computer" icon. Select "Properties" from the menu and click on the "Hardware" tab. Click the "Device Manager" button and expand the CD-ROM section. Right click on the CD-ROM and choose "Update Driver" from the menu to download and install the latest device driver from the CD-ROM manufacturer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Lenovo 3000 Y410 Notebook
Asus p4v8x-x bad bios checksum checking for floopy floppy not found checking for cd-rom start reading P4V8X-X.ROM could not find P4V8X-X.ROM May i know what's wrong with it? i've rename the .rom file...
This problem could be caused by a near flat BIOS battery. Replace the BIOS battery and go into the BIOS configuration and set the Date and Time etc.
Apr 11, 2011 | ASUS P4V8X-X Motherboard
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
My cd-rom won't read the disk that i am putting in.
If you have a can of air, blow it softly into the cd-rom to make sure dust isn't causing the laser to act weird. Then try a couple of different cd's to be sure and if the problem still exists, then the cd-rom is bad and it will have to be replaced.
Jan 29, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
Nov 17, 2008 | Dell OptiPlex GX270 PC Desktop
Rom Error
Replace rom, and acc. battery on main pcb.
Jan 30, 2008 | Canon FAX-L380 Plain Paper Laser
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
HP Compaq d530 SFF PC Desktop Logo
21 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
