Question about E-Machines eMachines Desktop PC
Disk for visa
How and where can i get a disk for visa for my emachines model emachines w3611.i had it but it got deleated my mistake and how much does coast
    New Friend:
Do you mean the upgrade disk; Windows Anytime Upgrade? If so, I have 1. Pm me @ thebrennjenn1999@gmail.com if you are interested because I am on vista ultimate!
Posted on May 01, 2013
    Champion:
  • 219 Answers
My suggestion is to go to emachines web site or call them, as far as what they tell you I have no clue..
Posted on Jan 24, 2009
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
May 12, 2015 | eMachines W3611 PC Desktop
How to install 4 gig ram on EMachine 3611
You cannot. See table below.
eMachines W3611 RAM Specifications
Standard Memory 512 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. CPU Type 3.0GHz Intel Pentium 4 631 Model Comments 800MHz FSB, Intel 945G Chipset
Jun 09, 2014 | Computers & Internet
Restore emachine factory settings
Do a system restore point/date and see if that will take your PC back to where all your settings were at and what you liked at the time before you made the change.
Dec 23, 2013 | eMachines W3611 PC Desktop
How to get hdmi on emachines model w3611 without buying anything, is there a plugin inside?
No. The W3611 only has a VGA output on the motherboard. To add an HDMI port, you will need a video card. If you choose an internal card, the machine will probably need a better power supply (400W or higher). You will also need to remove the card that is currently in the PCI-e x16 slot (probably the Fax modem).
There are some external video adapters that connect to the USB port. Some have HDMI out. However, if you want to play games or moves, these are often not a good option. They are limited by the USB 2.0 port.
CNET gives the specifications for the W3611 here: http://reviews.cnet.com/desktops/emachines-w3611/4507-3118_7-32329686.html .
I hope this helps.
(no computer has "hidden" video output ports. All have to be visible from the outside of the case.)
May 01, 2013 | Computers & Internet
I need to restore it to factory settings.
If you don't have a recovery disk, which they usually don't provide anymore, you can make one if the computer is still working properly. Type" recovery disk" into help & it should walk you thru it. Otherwise you can call or email the maker of the computer, which I think is gateway & order one. Then put it in the computer, restart & it should walk itself thru. You make have to go to setup when the computer first boots up & make sure it goes to the dvd drive first.
Oct 20, 2010 | eMachines W3611 PC Desktop
Upgraded memory in W3611. Won't start. Gives three long beeps instead. Restored old memory. Won't start. Gives three long beeps instead.
Remove RAM(S), clean the ram slot by blowing air, fix RAM(s) back in position untill both the side clamps are properly locked.
If problem persists try resetting motherboard via jumper pins on the motherboard.
Sep 03, 2010 | eMachines W3611 PC Desktop
Cannot remove websites from my favorites.
You might need Administrator permission.Make sure you have administrator rights. place curser on drop down URL and press right key mouse button select run as adminiistrator then try to deleate with right mouse button menue.
Nov 09, 2009 | eMachines W3611 PC Desktop
Freezes while trying to do fresh install from
this indicates a bad hard drive, or Ram or both
Jul 29, 2009 | eMachines W3611 PC Desktop
I don't know where to put my picture card at
according to eMachine's webpage, your dejtio should have a built in card reader.
It should look like this and will be located at the front of your computer: Your card should fit in the top right slot (according to this picture) or a slot marked with the words "SD".
Apr 19, 2009 | eMachines W3611 PC Desktop
Repalcing video card in emachine w3611
no signal try open your system unit get the memory then put it back then try to switch on your computer
Apr 07, 2009 | eMachines W3611 PC Desktop
E-Machines eMachines Desktop PC Logo
76 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
