Question about RCA HD61LPW165 61" Projection HDTV
Want to know if color wheel can be repaired?
The part # is 267888 the tv model # is HD44LPW62, also can you buy berings for the color whee and where?
  • 298 Answers
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
Posted on Jan 24, 2009
Hello, I have Philips R5A light engine 60" Every time i turn the TV, stays on for 10-15 seconds tops and then i start seeing like color distortion, i hear some fan scratching and then shuts off. at...
Thats usually caused by the color wheel needing replacement. Your model uses the 267888 color wheel you should be able to get a rebuilt one from www.tvrepairworld.com
Sep 13, 2011 | RCA HD50LPW175 50" HDTV
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
http://servicemanuals.vstore.ca/
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Part #267888 just wondering if color wheel can be repaired and how to do it. Can you buy berings for the color wheel and where?
That part is on national back order with no projected date of when it will be available. However you can get your color wheel rebuilt at the following link and they are fully guaranteed. Heres the link
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
Bad color wheel on hd44lpw62
yes. its a little tricky to remove because its inside the engine, but can be replaced seperately. let me know how i can help.
Jan 22, 2009 | Televison & Video
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
RCA HD61LPW165 61" Projection HDTV Logo
287 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
