Question about Admiral AAV7000A
Machine knocks and walks when spinning a small load
My Admiral washing machine starts to make a very loud knocking, and works its way across the floor when it is spinning a small or medium load.
It appears that the load gets out of balance, causing the knocking. Can anyone advise how to rectify this, please?
  • 4 more comments
  • simonabowles Jan 25, 2009
    Yes we have already checked this. The puzzling thing is that it used to work fine on this surface....and now it does not - as if something had gone wrong with the machine itself.
    Any other suggestions?
    Thanks
  • Anonymous Jan 30, 2009
    small loads and med. loasd seem to get out of balance never had this problem when it was new has not been abused used only 6 month out of the year machine like new except gets off balance most of the time i have noticed a white chalk material under main support almost like plastic dust.
    the springs look ok that hold the tub not weak.
    SMALL LOADS GETS OUT OF BALANCE ,WOULD A SNUBBER RING FIX MY PROBLEM?
  • eaglecrestga Feb 09, 2009
    i have the same problem with my machine. please help
  • thale7221 Mar 07, 2009
    I put in a load of any size and the inside starts moving from side to side as it spins knocking against the side very hard causing the machine to be loud and move back and forth.
  • bmino1962 Mar 22, 2009
    my admiral washer is not spining right, the clothes come out soaked. Looks like the drum is crooked. Any Help Please
  • 130 Answers
Amke sure it is level and on a solid floor with little bounce.
Posted on Jan 24, 2009
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
JUST GOT A NEW FRONT LOAD DUET WASHER - 3.7 AND IT IS KNOCKING AND MOVING ACROSS THE FLOOR. IS THIS A PROBLEM WITH THE MACHINE OR WHAT?
check to see if the shipping rods have been removed,also if machine is located on upper floor laundry room,the floor may not be sturdy enough to counter act the force generated during spin,this is a common issue in newer homes
Mar 10, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Loud knocking sound when in wash cycle GEWDSR2080
After taking off the front cover, look up at the top of the tub just under the lid. there should be a thick rubber strap at each corner of the machine tying in the tub to the top. These are called dampening straps. One or more may be broken. I usually replace all four if I do one.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
The problem is the brake. The odd time what happens is moisture gets on thebrake rotor and the squealing is heard when the brake stator is applied to stop the tub from spinning. This moisture, may drip down from the tub onto the brake rotor which could indicate a leaky tub seal. If you can't see any dripping when you fill the tub with water, don't worry about the tub seal. Many times than not the brake is just going sour on it's own.
Sometimes you can fix the squealing by cleaning the rotor and stator with a light sandpaper, such as emery/sand cloth. If that doesn't work you will need to replace the brake stator and rotor. If you need to replace them replace both parts together, don't just change the stator without also replacing the rotor, or vice versa. And here's a bonus tip: the brake spring exerts 200 pounds of force. If you try to remove the six 5/16" screws without using this brake removal tool, serious injury can/could happen!! The splined part in the middle of the brake needs to be greased really good before putting the brake back on!
Apr 01, 2009 | Maytag Washing Machines
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
My washer machine is making a knocking sound
Try balancing the clothes evenly,if that not the problem,the balancing ring at the very top is either broken or a snap ring or rings are off.
Jan 21, 2007 | Kenmore 15864/15862 Top Load Washer
Admiral AAV7000A Logo
249 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
