Question about RCA HD61LPW165 61" Projection HDTV
Part #267888 just wondering if color wheel can be repaired and how to do it. Can you buy berings for the color wheel and where?
It does not have bearings. Only a center shaft. Cleaning it and regreasing may help if it is not too worn out. Becarefull not to damege the sensor or glass or you will be totally out of luck. Carefully open the three scrows and the motor will slide out. Then you can slid it off the shaft.
Posted on Oct 22, 2010
Power button flashes 4 times on my rca hd50lpw62a why an thanks
Posted on Feb 07, 2009
  • RCA Master
  • 8,617 Answers
That part is on national back order with no projected date of when it will be available. However you can get your color wheel rebuilt at the following link and they are fully guaranteed. Heres the link
http://servicemanuals.vstore.ca/
Posted on Jan 24, 2009
2 Suggested Answers
  • 298 Answers
SOURCE: Want to know if color wheel can be repaired?
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
What's your problem?DIY Rca HD50LPW165 50in 720p DLP HDTV Color Wheel
thats the 267888 color wheel which has been discontinued for several years now. However you can get your color wheel rebuilt by contacting the guys at www.tvrepairworld.com
Mar 15, 2012 | RCA Televison & Video
Need a color wheel for RCA Scenium HD50LPW165 50 in Rear-
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
Oct 16, 2009 | RCA Scenium D40W20 40" Rear Projection...
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
RCA Scenium HD50LPW166XY1 DLP Projection HDTV ''scream''
RCA has discontinued the color wheel for your model and its on nationwide back order, so you cant buy the replacement. You can get your color wheel rebuilt at the following link and the rebuilt color wheels are fully guaranteed.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-color-wheel-267888-rebuild-option/cName/color-wheels
Jun 14, 2009 | Televison & Video
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Color wheel 267888
no the color wheels usually have a segment break off. they are very fragile. try and look on the TRITRONICS website
Feb 19, 2008 | RCA HD50LPW164 50" Rear Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
308 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
