Question about Carrier 36KCARMS Air Conditioner
Ive got an MITSUBISHI SRK40HGS DOSNT SEEM TO BE GETTING AS HOT AS IT USED TO ????
Overheating ACER ASPIRE 5733
Are you getting any warning the system is overheating? Have you cleaned out the inside of the computer of all dust? Dust on the heat sink is the big culprit here. Also make sure as few programs as possible are running in the background, the load increases the heat of the processor a little with each program that is running.
Jun 20, 2012 | Acer Aspire 5630 Notebook
Hi i have a hotpoint tcm condenser dryer and dosnt seem to dry my clothes anymore?
You need to clean all the fluff out of the dryer, the heat exchanger gets fluffed up, the fan gets fluffed up.I am assuming that the dryer is getting hot?
Mar 05, 2011 | Dryers
Onga Pantera ppp750 3 years old - thinking electrical problem? Pump is switching itself off randomly, dosnt seem to be getting hot (cool to touch) did hear a clicking sound before we manually turn it back...
If it is equiped with a starting relay,the relay is the problem,replace it with the same and better replacement.The contacts seems to loose it through wear and tear.
Dec 05, 2010 | Plumbing
Hoover 1200 performa dosnt seem to be getting hot? the drum feels cold when washing, any ideas?
Morethqan likely a faulty heater element, this is located a t the bottom rear of drum, remove rearr panel of washer to access, you will need a meter to test it.
Feb 07, 2010 | Washing Machines
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
My ryobi cs30 wont start
what do you do when there is no spark??????????????????
how do you fix???????????
Mar 26, 2009 | Ryobi 15" Electric Factory Reconditioned...
Specifications of a hyundai cope e 1.3 1998
i've just got the exact same car and year and it doesn't have power steering neither so i guess it must be right
Jan 18, 2009 | Hyundai Motor 1998 Accent
Carrier 36KCARMS Air Conditioner Logo
18 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
