Question about LeapFrog Scout My Puppy Pal
I can't scroll down on leapfrog connect for my pal scout
I have downloaded leapfrog connect but I can't scroll down on my netbook so I'm unable to do anything with it.
3 Suggested Answers
  • 910 Answers
SOURCE: I boaght 2 Leapster Explorers.
Have you tried the alternative LeapFrog Connect Installer from the link below, although I suspect it could be a classic Windows 7 Driver problem.
http://www.leapfrog.com/en/pages/support/product_pages/leapster_explorer.html
Posted on Jul 09, 2011
SOURCE: Tag will not update
I have had the same problem!! Running windows 7 64 bit. I am stuck in the same do-loop. I tried different usb port (as advised), downloaded 2 different installers from their web site, and verified the tag reader is "seen" under the USB controllers on my PC.
You also should check the following:
With TAG reader off, plug into USB port - if it does not automatically turn on device is defective.
IF it turns on do the following:
Click on the Windows start button (the small icon lower left of your computer). in the search box that comes up type devmgmt.msc and the device manager will open. Scrool down till you see Universal Serial Bus controllers and verify you see the TAG reader listed and verify there is no ! (exclamation point) next to it. If you see the exclamation point it may mean the driver is missing. If this is so right click and select properties, on the driver tab click update driver, on the next screen select browse my computer for the driver software. If you need to specify where to look try c:\Program Files\LeapFrog\LeapFrog Connect\TagUSBDrivers.
This was not my problem so I am still stuck - hope you solution was this easy. Anyone with any ideas I would appreciate help also. Customer service was unable to resolve.
Posted on Jan 04, 2013
My pal scout won't download from leapfrog connect it says error 400
I put in a new set of batteries and the data synced/downloaded to scout.
Mar 04, 2014 | LeapFrog My Pal Violet
I have a LeapFrog My Pal Violet (and Scout). The have been personalized with my child's name and favorite "things". My question is: How do I reset or clear this personalized information...
Here you are. It took a while to find the instructions!
In addition, if you would like to delete the data on your device prior to recycling, open the LeapFrog Connect program, sync your device via USB to your computer, click on the product you would like to reset from the "My Products" screen, then under "Settings," select "Reset". If you have not downloaded LeapFrog Connect, please follow these instructions to do so.
eWaste
Aug 26, 2011 | LeapFrog My Pal Violet
My granddog grabbed Scout and now Scout only plays one song. The toy wasn't ripped or even a hole. Can Scout be reprogrammed? When you push the pads it trys to play something else then goes back to the...
There is a possiblity that the ciructs inside could ahve been damaged but you could try reprogramming.
To reprogramme violet you will need to install the leapfrog connect software which you can download here (Windows) or here (Mac). Then follow the instructions in this PDF
Hope this helps
Mar 06, 2011 | LeapFrog My Puppy Pal Violet
My dauhter got the leapfrog my pal violet dog for christmas before receiving this my brother programmed in my daughters name and colour ect i want to change and add info myself but when connect the toy...
You have to download the software for your computer that allows you to connect Violet in order to change the name, etc. Once you do that, connect Violet with the cable included and follow the steps. If you need more help let me know. It's a little tricky sometimes if you don't do things in the precise order.
Dec 29, 2010 | LeapFrog My Pal Violet
How to use my puppy pal
this site is good enough to guide you and give you the information that you might expect ...
http://puppypalsrescue.com/
Jan 01, 2010 | LeapFrog ClickStart Educational Software:...
Mouse is not communicating with the unit
if u have connected after the system has started you need to restart it to make it functional ...
if its a 'USB mouse no restart requires...
if neither works probabily problem with mouse ..just replace it !!! instead of wasting time
Nov 26, 2009 | LeapFrog ClickStart Educational Software:...
The leapfrog clickstart lights aren't communicating. Same problem as first poster
Call Leapster. You can send that in and get a new or refurbished same product.
May 29, 2009 | LeapFrog ClickStart Educational Software:...
I got a leapfrog click start my first computer
yes there should be two parts. First there is the actual computer and the second is the base (where the games are connected to). The television should be set where you would usually watch a dvd/or play  a game(depending on what model tv) the computer is wireless so you can use it from the sofa etc. but you must have the base in order for the game to work. I just purchased one and my son loves it.
Mar 08, 2009 | LeapFrog ClickStart Educational Software:...
Hi i recently bought a 9volt adapter for my vtech smile console for my kid.. and tried using it on the Leapfrog Clickstart and it worked even though it only needed 5volt for an adapter. Worked good for 2...
If you plugged in a 9 volt power supply where you only needed 5 volts, you probably burned something out. Although the power cords have the same end, the voltages are critical. You can try to get the Leap Pad replaced but, I wouldn't get my hopes up.
Jan 31, 2009 | LeapFrog ClickStart Educational Software:...
Leapfrog Clickstart doesn't switch off and doesn't work
You blew the circuit board by putting to much power into it. Never use more power then suggested for this reason. All adaptors have a volt and an amp rating. Sorry it happend best wishes!
LeapFrog Scout My Puppy Pal Logo
167 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
relojmesa
GI Consulting
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
