ERROR CODE C-3423 oN KONICA MOMOLTA 283 - Office Equipment & Supplies
2 Suggested Answers
  • 44 Answers
SOURCE: como vou resolver o erro
Its a fuser code. To reset it the code and get it to work again.
1)Turn the main power off ( the switch behind the toner door )
2)Hold down the Utility button while you turn the machine back on.
3)Keep holding till you see "Trouble reset"
4) Push trouble reset then turn off and on the machine and will start working
Posted on Sep 06, 2010
Cause of trouble code 3423 in konica minolta c353
In fixing unit-Pressure roller heat-up failure.
Need to look Fuser unit for its lamp and Thermistor dirtiness.
Jul 28, 2017 | Konica Minolta Office Equipment & Supplies
How to clear error 3423 in Konica Minolta 203
Switch On by holding Utility Button.
keep holding until Troubleshoot icon appear on the screen.
Then Touch it and switch Off and on in normal ways.
Jul 27, 2017 | Konica Minolta Office Equipment & Supplies
Konica bizhub 283 photocopier error code c9401
FIRST, if this code comes back. Have a technician look at it the exposure lamp the bright light under the glass is bad or the board controlling it.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 22, 2017 | Konica Minolta Konica Bizhub 283 Copier,...
Konica minolta c280 showing error codes 3423, 3334 and 2451 How can I clear the codes
2451 replace the cyan (Blue ) Image unit
3423 replace the fuser unit
3334 No such code
Jan 09, 2017 | Konica Minolta Bizhub C280 Color Copier /...
Error code 202in konica minolta 283
turn off the machine hold down the the utility/counter then turn it on while holding until the screen displays reset select it and turn off and on that should clear the error
Aug 23, 2016 | Konica Minolta Konica Bizhub 283 Copier,...
Error code c-3423
that is GOOD did you touch the trouble reset, yes then power off and turn on should be go to code if the code comes back then replace the the code does not exsit in the service manual what is the code C-34??????
Apr 22, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 283 trouble code 3423
if after this procedure code come back replace the fuser, attempt again machine my catch on fire that would ruin a perfectly good day
1.
Apr 17, 2014 | Konica Minolta Bizhub 283 Copier
How to reset error code 13 on konica minolta bizhub 283
missing some number on the code code is C-XXXX
Nov 26, 2013 | Konica Minolta Bizhub 283 Copier
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Sep 11, 2013 | Konica Minolta Bizhub C220 Color...
213 people viewed this question
k24674
jasbo
jasbo
