Question about McCulloch Garden
Need to know spacing requirments for magneto on mcculloch model # 600016h. is it possible to test coil and how would you do so?
  • 1,214 Answers
Spacing is probably .010. You can test it by getting a flashlight battery and light. Connect the base of the light to the spark plug cable. Connect the ground wire of the coil to the bottom of the battery, and hold the other end of the battery on the light. If the light lights, the coil is good. If not, the coil is bad.
Do not use anything over a 1.5 volt flashlight bulb and battery. The bulb does not have to glow, just light, to prove the coil.
Posted on Jan 23, 2009
How to test my magneato igntion coil
Sounds like the magneto has gone bad and needs replaced. It may possibly be something in the charging system, but its more likely the magneto is bad.
Jan 23, 2014 | Motorcycles
Mcculloch parts manual
you can purchase the magneto at most any parts shop unless its an obsolete saw. the magneto is located on crank cooling fins under the pull start
Jan 07, 2014 | Garden
I have a Powermate Generator which I bought about 3 years ago from Lowe's. I start it up and run it every few months. Now it will not start. I took the magneto off and cleaned the inductor magnet in...
Remove all the wires at the coil and retest. Good idea to use a new plug for testing or insert metal into plug cap and then hold close to metal of engine. If still no spark, remove the coil and take to small engine shop for free test (may have been damaged by heat if it was making contact with flywheel). I use a growler to test the coil. If retest produces spark, most likely faulty oil sensor. Remove the wire from oil sending unit. Dont replace the oil sending unit, just check oil often.
Sep 09, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
Id like to know if you can test your magneto without a multi circuit tester ? if i am getting spark, is my magneto still good? how do i read the numbers to know what year i in fact have ?
If you are getting a strong, blue, spark on a known, good spark plug, then the magneto is good. If the spark is weak (barely visible), then it is most likely the clearance or rust build up.
The easiest thing to do is check for rust on the surface of the magneto and the surface of the pick-up coil. Emery cloth is good for removing rust on both. Then check for the clearance between the pick-up coil and the magneto. The closer to the magneto, the more powerful the spark (but rotate the magneto to ensure it never touches). When you loosen the screws on the pickup coil to adjust, make sure you have a business card to place between the surfaces to keep them from touching. The strong magnet in the magneto will pull the pickup coil to itself. Tighten the screws and remove the business card. Check for clearance as you rotate the magneto.
The only thing that can go bad in a magneto situation is the pickup coil. So, if you're getting a spark, it most likely is not the pickup coil because it will either produce a spark or won't.
May 31, 2011 | Suzuki RM 250 Motorcycles
I would like to know how to test a solid state,magneto
with a spark tester .some motors require an external resister on the solid state units
Mar 28, 2010 | Boating
No spark on Mc Culloch 110 saw
Remove the stop switch wire from the switch and check for spark (use a clean spare plug and the plug base touching engine metal), If nothing, trace the wire back to the ignition coil looking for worn insulation. Is this a magneto model or an all-in-one module? If a magneto, there should be points and condenser--check points gap (about 0.015") and condition. Check the core gap to flywheel magnets (I use card stock to set the gap). Try to wiggle the flywheel to check for crankshaft bearing looseness. If the ignition is an all-in-one module, check the core gap to the flywheel magnets. Otherwise replace the module. Hope this gets you running.
Aug 26, 2009 | McCulloch Garden
McCulloch 3200 takes many pulls to start, runs good when does.
I don't think I can help, but normal starting procedure for me is to put choke on, pull on recoil until it kicks over once. shut off choke and restart. Sounds like you have fixed almost everything & adjusted mag right. Rick
Mar 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch Chain Saw model # 600016H
the cap is usualy around 0.47 MFD....if the spark is blue its ok check the piont for clean surface and correct gap .015" is a good start.
Jan 25, 2009 | Garden
Garden Logo
298 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
