Question about HP LaserJet 3300 All-In-One Printer
I have an HP laserjet 3300...it has performed flawlessly for several years. It just stopped printing recently, and gives error message that there is no communication with the device. I unplugged the usb from my desktop and plugged it into the laptop running vista. Uploaded drivers etc. Tried to test print, and got the same error message.
    Scholar:
  • 97 Answers
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,
raj_p5983
Posted on Jan 23, 2009
My HP LaserJet printer 5200dtn is displaying error message "50.3 Fuser error" what is the solution to this problem because I can't print
50.3 means the fuser is getting too hot. It will either be a problem with the thermistor in the fuser or the power supply. If you can find a another fuser to test with you can answer the question pretty quickly.
Mar 02, 2015 | HP LaserJet 5200dtn Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
My HP laserjet 3015 doesnt print and gives "Device Error" message
IF its under warranty get it back where ya bought it
if it isnt it cost more to repair than a new printer...sorry to say time for a new printer
Aug 27, 2009 | HP LaserJet 3015 All-In-One Printer
Scanner bulb warming up doesn't go away
Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner?s inability to find the home reference point.
Perform the following steps to troubleshoot the issue:
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle
5. Please ensure that the current firmware update (20021018W) is installed. You can download and install the same from the link given below:
http://welcome.hp.com/country/us/eng/support.html
Please follow the steps provided below to download the driver:
1. Click on the option "download drivers and software".
2. Enter "LaserJet 3300mfp" in the search box and press enter key.
3. Select Cross operating system (BIOS, Firmware, Diagnostics, etc).
4. Click HP LaserJet 3300mfp firmware update for windows.
HP LaserJet 3300 MFP Series Products - Firmware Update Utility Installation
Security level: HP and Customer Viewable
___________________________________________________
NOTE: To ensure an easy and successful upgrade, it is essential to read and follow the instructions below.
CAUTION: Disconnect all devices except the HP LaserJet 3300 that are directly connected to the computer before performing the Firmware upgrade.
Make a copy of any document either through the automatic document feeder (ADF) or on the flatbed. Save the original and the copy to make a comparison after the firmware update.
Print a Configuration page to confirm the existing firmware date code.Firmware version
Firmware datecode
E
20020424
F
20020612
F-wide
20020612W
G
20021018
G-wide
20021018W
Press the Menu/Enter button.
Press the < or > button until Reports appears in the control panel display, then press the Menu/Enter button.
Press the < or > button until Configuration Report appears in the control panel display and press Menu/Enter. The product will exit the menu settings and print the report.
Close all applications and TSRs before running the firmware update.
Simultaneously, press and release the Ctrl, Alt, and Delete keys to open the Close Program window.
Highlight one item and click End Task.
Repeat this procedure until all programs are closed, except for Explorer and Systray.
If using an HP LaserJet 3330 (the fax model), disconnect the phone line from the device to prevent interruption from an incoming fax.
Verify that the computer has 50 MB of free disk space in order to successfully run the Firmware Update Utility.
The utility can run using either a parallel or a USB connection (USB is not supported in Windows 95 or NT):
If using a USB cable, it is important to first install the HP LaserJet 3300 MFP series software before running the utility (the USB ports and connection are established during the software install).
If using a parallel cable, simply attach the cable and the utility will find the connection automatically.
Save the setup of the unit if a large number of speed dials or other special configurations have been entered.
NOTE: A speed dial report could be printed instead, if the printer is not connected to a computer or if the software is not installed.
Select Start, Programs, HP LaserJet 33xx, Tools, then HP LaserJet Device Configuration to open the HP LaserJet 3300 device configuration.
Click Save to File on the lower left of the General tab.
Select a destination and a file name to save the configuration. Write down the information for retrieval later.
Proceed with the upgrade.
Restart (reboot) the HP LaserJet 33xx device.
Download the HP LaserJet 3300 Firmware Update for Windows from the HP Web site. Click here to download the Utility from www.hp.com.
Begin the upgrade.
Double-click the file named lj3300fwutilitywin-en.exe. When the file opens, click the Start button and allow the utility to run uninterrupted. The product display will initially read Printing Document. After about a minute, the product display will read Updating. Several minutes later the display will change to Completed. The display will then change to Scanner Bulb Warming Up as the new firmware initializes.
Finally, the display will show Ready in the top-left corner. Depending upon the operating system on the PC, the software might prompt Please reboot your Computer. Close the screens by clicking OK.
Reboot the PC, if necessary.
Take the original document that was copied at the beginning and copy it again to compare results. If further assistance is needed, contact HP at 1-800-HPINVENT (1-800-474-6836).
Print a new Configuration page to confirm the new firmware date code.
If speed dial settings were backed up, check to see if they remain in the machine. If they are now blank, restore the configuration with the following steps.
Select Start, Programs, HP LaserJet 33xx, Tools, then HP LaserJet Device Configuration to open the HP LaserJet 3300 Device Configuration.
Click Retrieve from File on the lower left of the General tab.
Select a destination and a file name to open (the file that was saved previously; see Step 7 above).
Click Open and wait for the file to download and reconfigure the product.
Click OK to close the HP LaserJet Device Configuration.
Aug 27, 2009 | HP LaserJet 3330 All-In-One Printer
HP Color LaserJet CM1017 MFP - won't scan
Please try installing software components for your MFP device.
Feb 12, 2009 | HP LaserJet CM1017 MFP All-In-One Color...
Print not comming
my printer hp 2300 print only on page
Sep 17, 2008 | HP LaserJet 2300 Printer
Error message on HP 2600n
Connect to it through usb/parallel from your laptop, If this works then check your settings through your wireless connections,Hope that helps
Andy
Jul 10, 2008 | HP Color LaserJet 2600n Printer
HP 4350 ERROR MESSAGE: 49.2F90
he printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Printer won't print all of a sudden
try with re-installing the driver and see. bye
Sep 25, 2007 | HP LaserJet 4L Printer
HP LaserJet 3300 All-In-One Printer Logo
168 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
