Question about Minolta CF2001 Copier
Fault code C0500
Does anyone how to clear this fault without calling in a engineer please
  • 186 Answers
That error code indicates a fuser problem. Most likely the heater lamp or thermistor is faulty. In either case it is definitely a job for a tech. Sorry John
Posted on Jul 10, 2007
Reset check engine light on a 2008 Buick Enclave without going to a garage
Anyone with a scanner can erase the codes and reset the light. On older cars, you could just remove the negative battery post for a few minutes, but that is not recommended for newer cars. Erase codes with a scanner.
Dec 09, 2013 | Cars & Trucks
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Dec 13, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
The machine di251f is saying contact your technician with code error c0500 please help
C0500: Warming-up Failure
error code c0500, checked lamp and thermo fuses, checked thermistor ok. reset machine
Jun 17, 2011 | Minolta Di251 All-In-One Printer
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Code C0500
hold down exposure key (<) while turning on power, u-1 will display. prss start, select clear mode, prss clear/stop
Dec 15, 2008 | Minolta EP1030/1030F CS/PRO Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
C0500 Code in Dialta 3010
Clearing C5XX codes on Minolta Di2010/2510/3010/3510:
1. Push Warm Restart button (small button on right side of control panel. A small dot should appear on the left edge of the touchscreen.
2. Enter "3" on the keypad. This should get you the Initialize menu.
3. Select "Trouble Reset" at the bottom of this menu.
That should do it.
Jun 12, 2008 | Office Equipment & Supplies
Malfuntion Call a technician Code C0500
FUSER CODE. NOT SURE ON THIS SAME MODEL BUT ON OTHER DiALTA'S YOU NEED TO DO WHAT IS CALLED A "WARM RESET OR WARM REBOOT". tURN COPIER ON AND FIND A VER SMALL HOLE (PAPER CLIP SIZE) ON KEYBOARD OR SOME TIMES ON RIGHT HAND SIDE OF KEYBOARD, SOME TIMES SMALL SQUARE HOLE. STICK PAPER CLIP IN HOLE AND THAT WILL BRING YOU INTO SERVICE MODE. PANEL WILL SAY TROUBLE CODES, DEPRESS. TURN COPIER ON AND OFF AND SEE IF IT GETS YOU GOING. IF PROBLEM COMBES BACK YOU HAVE A BAD FUSER, EITHER FUSE, THERMISTER OR CONNECTORS.. GOOD LUCK
Jun 11, 2008 | Konica Minolta DiALTA CF910 Copier
Code C0500
simulation = UTILIY -----> METER COUNT (on touch screen)->
STOP------> 0-----> 0------> STOP------>0------>1
Sep 07, 2007 | Konica Minolta DiALTA Di200 Copier
91 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
