Question about Yaesu Ft-60r Dual Band Vhf / Uhf Handheld Ft-60r
Ft-60r monitor button - Yaesu Ft-60r Dual Band Vhf / Uhf Handheld Ft-60r
Will 235 70r16 tire go on 2008 chevy impala
For the 50th anniversary edition model, P235/50R 18
For the LS model Impala, P225/60R 16
For the LT model with a 3.5 liter engine, P225/60R 16
For the Lt model with a 3.9 liter engine, P225/55R 17
for the SS and LTZ models, P235/50R 18
Source: Goodyear Tire Manufacturer
Feb 19, 2017 | 2003 Chevrolet Impala
Dead Yaesu FT60R
There is probably an internal fuse which has blown. Send it to the Yaesu service center for repair. They're reasonable and will do good work...
Jun 27, 2013 | Yaesu Ft-60r Dual Band Handheld Vhf / Uhf...
Can I put 215 60R/15's wheels on a subaru impreza that is supposed to take 205 60R/15's?
You are only going 1 size bigger, shouldn't be a problem. You may experience occasional noise from tires bumping the body if you have a heavy load in the car or maybe the tires rubbing when you make a sharp turn but that should be about the only difference. Hope this helps.
Aug 12, 2010 | 1998 Subaru Impreza
What is the original tire size for 99 mercury cougar? please
the 1999 mercury cougar take tire size 205/60r-15 if it has a 4 cylinder engine. if the car has a 6 cylinder engine then it uses 215/60R-16 tires. good luck hope this helped.
Jan 25, 2010 | Mercury Cougar Cars & Trucks
How much air pressure in my tires ? 185/60R 14 I
34 PSI IS THE MOST WIDELY RECOMMENDED PRESSURE FRONT AND REAR.
Jul 17, 2009 | 2003 Hyundai Accent
Tires for a saturn
They will fit but be prepared for different response at steering wheel, for example if you take your eyes of the road for a second it may wander quicker, when you turn it may turn quicker, and also might hydroplane easier in wet weather. Your going a little wider & little higher sidewall height. Speedometer may be off a little too. It's like putting a little wider ski on in the snow too, it may slide on top a little more, instead of biting in and grabbing. Be real careful until your used to the feel.
Dec 22, 2008 | Dodge Caravan Cars & Trucks
Yaesu Ft-60R with Kenwood TK-3107
ok guys!! i have gold for your prob huhuh
go to this website and u can get anything about all model TK
http://www.twowayradioearpieces.com/Programming-Cable-for-KENWOOD-C178-1.htm
Oct 31, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Yaesu Ft-60r Dual Band Vhf / Uhf Handheld Ft-60r Logo
23 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
