Question about Garmin nuvi 780 GPS
Garmin 780 My garmin 780 will not give instruction
  • 385 Answers
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
or map data, such as street names.
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
You should be good now
Regards
Richard.
Posted on Apr 21, 2009
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
How do I change the battery in a nuvi 780?
Replace Nuvi 780 Battery - NewPower99.com‎
Adwww.newpower99.com/Nuvi/780/Battery‎ Garmin Nuvi 780 Replacement Battery Tools and Instructions Included.
Full 1 Yr. Warranty · How-to Video Included
Types: GPS, Auto GPS, Bike GPS, Camping GPS, Cycling GPS, Hiking GPS, Motorcycle GPS, Watch GPS, Golf GPS
Search Results
How To Replace Your Garmin Nuvi 780 Battery - YouTube
? 3:55
https://www.youtube.com/watch?v=Xd3vcThmXUI
Feb 8, 2010 - Uploaded by NewPower99DotCom
Part of the Complete Installation Kit from NewPower99.com, available at http://www.newpower99.com ...
Garmin Nuvi 780 Battery Replacement - YouTube
? 4:00
https://www.youtube.com/watch?v=A2pKE1S3tXo
Jan 14, 2012 - Uploaded by NewLife2OldStuff
Amazon.com: Battery Replacement Kit for Garmin Nuvi 780 with ...
https://www.amazon.com/Replacement-Garmin-Nuvi-780-Installation/.../B003VFY7A... Rating: 3.8 - ‎28 reviews
Replace your Garmin Nuvi 780 Battery or Keep an Extra Battery on hand as a backup. This is a High Capacity 1250 mAh, Lithium-Ion Battery that offers even more up time than your original. Works in your Garmin Nuvi 780 GPS. Simple, Easy and Inexpensive! You get a New Battery, FREE Special Tools (necessary for ...
Peel open a nuvi 780 to replace the battery? ' POI Factory
www.poi-factory.com > Garmin talk Feb 2, 2009 - 27 posts - ‎16 authors
I've got a DOA nuvi 780 that I bought on eBay. It works fine while plugged into car or computer but the internal battery only holds a charge for about 15 minutes. So I guess it's not really DOA but it needs a heart transplant. Or maybe the correct analogy is a FAT transplant since the body uses fat to store ... Rejuvenate a Nuvi Battery?
30 Sep 2011
owner rplacement of nuvii batteries
10 Jun 2009
More results from www.poi-factory.com
Garmin Nuvi 780 GPS Batteries at Batteries Plus Bulbs
https://www.batteriesplus.com > Batteries > GPS > Garmin Whether you're traveling across the country or just to an unfamiliar part of town, you rely on your GPS to get you where you're going. Unfortunately, a dead GPS battery isn't going to get you anywhere. If you're Garmin Nuvi 780 GPS needs a new battery or you just want an extra on hand just in case, Batteries Plus Bulbs can ...
Feb 12, 2018 | Garmin nuvi 780 GPS
Text to voice
yes it speaks directions and street names, but it must be turned on. refer to the user manual for instructions
Jun 03, 2010 | Garmin nuvi 780 GPS
Garmin nuvi 780 says no data found and no maps
Sounds like the data on your SD card is corrupt. If you know somebody else with the same unit and model try their SD card. If not them you are most like going to have to buy a new SD card and install the maps and operating system onto the new card. Should be instructions on you install Cd assuming you have them.
Apr 26, 2010 | Garmin nuvi 780 GPS
The 780 garmin gives directions such as turn left or right but is not giving the names of the street to turn on
does your unit state that it should be "Text to Speak" if not then it is not ment to, if it should then the map may not be correct to support it, or you need a software update, free from www.garmin.com, failing that the function mey be switched off
Dec 22, 2009 | Garmin nuvi 780 GPS
I have no sound on my garmin nuvi 780. i've hardly used it...
This same thing happened on my nuvi 780 and I just had to go into settings and re-select English as the language and it started working just fine.
Nov 13, 2009 | Garmin nuvi 780 GPS
My garmin 780 doesnt have any sound -voice. It says "none found" under language.
My Garmin 780 says the same thing. "NO VOICE FOUND" I reinstalled voiced like 5 times already. And after a little while voices dissapears again! What the heck is wrong with this unit????
Sep 23, 2009 | Garmin nuvi 780 GPS
Our Garmin Nuvi 780 is new and worked fine the first 2 times we used it. However, it will not give us the voice instructions now and we can't find instructions to reset or correct the problem. The online...
You can check "settings", then look for the picture of "lips". This is the language area. I always just select American English. You can set whatever you like. Also, check your volume setting. Just touch the "speaker" on the main screen and up will come the volume. Increase to a level you like. I use 90 percent.
Jan 01, 2009 | Garmin nuvi 780 GPS
Garmin nuvi 780 GPS Logo
394 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
