It keeps showing the above message turning itself off and on? What can I do the updates are up to date.
SOURCE: I've installed an ATI RADEON HD 4670. when i try
Try this. Uninstall all ati drivers, then maybe you should use Driver cleaner pro to remove all driver components.
Install net framework 2, then install driver again.Good luck.
SOURCE: I have a Dell Vostro 400 and two video cards. Only
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
SOURCE: i have a nvidia geforce 9400gt display driver but
there is a software conflict which is stopping the display unit.remove previous driver and install an updated one.please disable any integrated motherboard VGA display unit on your BIOS
SOURCE: update of ATI Radeon HD 2400 is causing problems -
Click the START MENU, click the CONTROL PANEL. Locate the APPEARANCES AND THEMES link. Click the DISPLAY tab or MONITOR Tab. In this option, a DROP BOX MENU will be available. Click the ATI RADEON HD 2400 PRO device. It may say something similar to MULTIPLE MONITORS. After doing so, you may configure the MONITORS as to giving them a position such as MONITOR #1 AND #2. You may do this by DOUBLE CLICKING the monitor example pictures above the drop box menu to verify which monitor will be your main DISPLAY.
Your graphics card drivers may be out of date. I suggest you download and install the very latest drivers for your card. You can reach the Nvidia wesite here.
Then go for option 2. It'll automatically find the drivers for what ever Nvidia card you have.
Testimonial: "Thanks a lot for the link mate, I will give it a shot and monitor the temp on it, to see if I can try other things. Justin"
