Question about Porcher 83420-00.000 L'Expression Toilet Replacement Flush Assembly
Porcher flush vale - Porcher 83420-00.000 L'Expression Toilet Replacement Flush Assembly
2 Suggested Answers
fklaske
SOURCE: our Porcher veneto 1 piece toilet does not flush. Does porcher have recommended repair service near zip code 94901 ?
I have three of these beautiful babies from when I redid my bathrooms back in the early 2000s -- and one of them started to leak (would keep flowing a small amount into the bowl after filling the tank), so I did some online sleuthing and came across the parts as well as the how-to for a complete rebuild of the critical parts -- and rebuilt all three and they work like new. I am in zip code 94552 so if you need help from a licensed general contractor -- give me a call at 510-909-8813 and I can see if I can fix it for you (for a charge, of course).
Posted on Oct 07, 2012
After flushing the water filling mechanism does not refill the cistern
then replace the mechanism we can not do it for you .
Sep 30, 2017 | Porcher Home
Where can I get a Porcher L'Expression flush valve gasket?
I was in the same situation. Cost me $2.38 to fix. Ordered 12" x 12" rubber sheet from Sustainable Supply and made my own flush valve. Easier than I imagined. All I did was trace the old flush valve on to the sheet with a Sharpie and cut it out with a pair of scissors. Yep, it was that easy. I ordered the 1/32" sheet and it worked on the first try. I would order the 2/32" next time because my handmade flush valve is a little thinner than the original; however, it works perfectly. I was shocked. I had searched the Internet and called all places I found and then decided to give it a go on my own. Here are the specs....it works.
Sku: C1749648
Rubber, Buna-N, 1/32"Thick, 12"x12", 70A - 4070-1/32A
Jan 21, 2016 | Porcher 83420-00.000 L'Expression Toilet...
Not sure part need - problem with flushing
http://www.guillens.com/index.jsp?path=product&part=22791
Mar 11, 2014 | Porcher Home
Leaking toilet from overflow
if you flush and the water continues to run into the bowl the it is the flush washer that needs repalcing
If that water shuts off and the cistern fills and then continues so that it flows down the over flow pipe into the bowl the it is the water inlet control washer that needs replacing
Feb 20, 2018 | Porcher Home
Where do I get porcher 83420
Hello--
That particular model has been disontinued; however, you may want to contact Customer Service to see if there are any spare parts in stock.
http://www.porcher-us.com/contact.aspx
Paul, ASB
Sep 20, 2011 | Porcher 83420-00.000 L'Expression Toilet...
My porcher toilet wont flush.... Push the buttons but nothing happens, have managed to open the top successfully and can manually flush by pushing on the ballcock but buttons still not working.... any...
Hello:
Please feel free to call Customer Service 1-800-359-3261
General Customer Service
Monday through Friday
8:00 A.M. to 7:30 P.M. EST
Technical Customer Service
8:00 A.M. to 6:00 P.M. EST
8:00 A.M. to 3:00 P.M. EST
Customer Care at Porcher Porcher Customer Care
P.O. Box 6820
1 Centennial Plaza
Piscataway, NJ 08855-6820
All the Best,
Paul, -ASB
Sep 12, 2011 | Porcher Home
How do i take the lid of the cistern
There is a trick to this for Porcher toilets. Push big flush button down, then lift up and out the small button. The big button lifts out. Undo plastic bolt and lift up lid. cheers, zoofish
Dec 18, 2010 | Porcher Toilet Seat Veneto 70032.001
Does not flush completely. Works 2 out 3 times.
Needs new flushing mechanism. Remove Cistern, Remove flush siphon and either replace siphon washer or replace complete siphon.
Jun 09, 2009 | Porcher 40050 Classic Elongated Toilet...
Porcher 83420-00.000 L'Expression Toilet Replacement Flush Assembly Logo
64 people viewed this question
Top Porcher Home Experts
bobalix
ray gallant
Stan Ford
Are you a Porcher Home Expert? Answer questions, earn points and help others
