Question about Ovens
Neff B1442N0GB/01 manul - Ovens
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Neff t2766n0/01 FD 8307/0895 diagram
Google "Neff service agent" in your local area
Oct 13, 2013 | Ovens
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
Neff oven film strip has become dislodged so not showing temp.
replace it is the only way goto
bshappliancescare.co.uk
Jun 28, 2009 | Ovens
Hello could you tell me were i can get the glass front door from for a neff b142wogb/01
yes you need to go online to bosch website and look for quickfinder this is the tool used to locate spares, the site is for bosch neff seimens as they are all one company put in your enr number or model number and you will get an exploded diagram of your oven you can then find part number.
I looked and it appears to be 297595 in brown or 297601 in white retails at £61.03 ex vat
HOPE THIS HELPS.
May 09, 2009 | Neff B1421 Electric Single Oven
Can not remove element
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Apr 02, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
