Question about Maytag Sovereign 60CZ Side by Side Refrigerator
Climate Zone Drawer not working
The vegetable CZT drawer has stopped working and the control panel for the drawer is not lit. I cannot see how to deatach the unit to check all the electrics etc.
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
  • 21 Answers
SOURCE: Vegetables freeze in vegetable drawer - actual ice
bad seal
Posted on Mar 23, 2009
SOURCE: Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Posted on Apr 14, 2009
  • 24 Answers
SOURCE: why do vegetables freeze in the vegetable drawer?
Have you put a good thermometer in the refrigerator, let it sit there for an hour or so without opening the door and then checked the temperature? If you're near 32 degrees, you've found the problem. Temperature uniformity is usually a problem in refrigerators...thus the fans, but ideally the temp should be in the mid 30's (34-38 degrees) rather than low 30's or you'll be freezing someplace
Posted on Nov 08, 2009
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
Maytag climate control drawer fan is not running.
Refer your inquiry directly to Maytag or an appliance parts supplier.
Jun 28, 2014 | Maytag MZD2766GES Side by Side...
Water build up
Good Afternoon Friend,
I understand that you are getting puddles of water in the back of one of the bottom shelf and in one of the vegetable drawers in your Frigidaire refrigerator. I suggest putting the crisper drawer control on the Hi humidity setting. This should allow more moisture to escape out of the drawer and not cause as much puddling. Also, check your water filter and make sure it is not leaking, as well as any moisture from the ice maker. If further troubleshooting is needed, I ask that you please leave the model number of your washer. Typically, you can find this number inside your refrigerator on the liner walls. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire Refrigerators
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
The top drawer has stop working. There is no power going to it
Not sure how you can work out if power is going to the top drawer. If the controller has gone faulty then you will not see anything on the display. The controller is located on the front of the drawer unit behind the door panel.
Oct 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Apr 14, 2009 | Refrigerators
MSD2758GEW Climate Zone Drawers
This fridge is garbage. Fixed ours 14 times in 6 years. WILL NEVER BUY ANOTHER MAYTAG ANYTHING AGAIN!!!! CLIMATE ZONE TECHNOLOGY DRAWERS NEVER DID WORK CORRECTLY....EVER.
Jan 31, 2009 | Maytag MSD2758GEW
Fisher and Paykel dishwasher double drawer problem
Hi there FM, Your Dishdrawer is it intergated or does it have a factory finish on it? This will help me ask the next question? Kind Regards Carmen
Aug 08, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher not working
disconnet power to unit....circuit breaker...wait 30 minutes....try again
Jun 02, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Maytag Sovereign 60CZ Side by Side Refrigerator Logo
46 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
