What causes the fuse to blow
SOURCE: Heater won't blow hot in my coleman Seapine
did you try the limit reset button? It is red and may be close to the blower.If your pilot is on and burners don't come on this may be it
SOURCE: We done' use our coleman hot water on demand
I had a similar problem and was able to unscrew the screen at the end of the intake hose and manually move the pump propellor with a long nail which loosened it and it works fine now. I think it had seized with calcium deposit even though I had cleaned it as instructed.
SOURCE: What is the pumping rate (volume) of the Coleman
I recall 3 and a half liters per minute. More than the Primus and the Cube
SOURCE: Our Coleman hot water on demand does not run at
You may have blown the internal fuse. Remove side cover, locate the circuit board and fuse, replace and reseal reinstall side cover.
