Question about Watches
Tmg3258a pod watch - Watches
I need instructions for a pod 512 mans watch
Not sure what a pod 512 is, but I think this manual should cover it. http://assets.timex.com/user_guides/W240_M805/W240_M805_all.pdf
Oct 02, 2017 | Watches
Could I use the Nike+ pod together with a Garmin forerunner 210?
Nope: Different types of signals.
That being said, there is a foot pod that Garmin makes if you want that type of data sensor. The GPS in the 210 is more accurate than the Nike+ pod, and the Garmin foot pod is about equally accurate with the 210, but allows you to use the watch when there is no GPS signal
Dec 18, 2010 | Watches
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Forerunner 50 Foot pod not sinking with watch
I'm not sure this is gonna help, but you can try this site: http://www8.garmin.com/support/userManual.jsp?market=67&subcategory=68&product=010-00679-05 You might be able to solve the problem.
Rate me, plz.
Jan 11, 2010 | Garmin Forerunner 50
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
"LoBATT" stays on in TIME mode (doesn't flash) ?
"lobatt" display is the watch battery. The foot pod uses the LED to indicate low battery and the heart rate monitor wont give a reading.
Oct 05, 2009 | Garmin Forerunner 50
Pairing Food Pod
I had the same issue, it turned out to be a weak battery. Also when you replace the battery make sure it is making proper contact with terminal in the foot pod.
Feb 18, 2009 | Garmin Forerunner 50 Heart Monitor
INSTRUCTIONS FOR SETTING UP A POD 510 WATER RESISTANT MENS TIME WATCH
my pod watch will not restart,it's frozen,also can't find instructions so I can set correct time.
Aug 26, 2008 | Watches
Watches Logo
52 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
