Question about Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic yh42pa20 shut down issue
I have the panasonic th42pa20 that shuts doun after a short while, what is the part number that needs replacing, power switch blinks 5 times, please help
  • 267 Answers
There are a number of parts that may cause your problem power supply, z or y sustain boards, drive boards or panel. needs a qualified servicer to check out.
Posted on Jan 24, 2009
Zero turn mower shuts doun when trying to go when engaging control arms
On my RZT50 Troy Built I have to engage the parking brake to start it and release it before I move the arms in over my lap or it shuts down.
Dec 10, 2016 | Garden
Panasonic SA-DM3 shutting down problem
You should check all your connections to your speakers. Also check each speaker to make certain there are no shorts in them. Check all speaker wiring for shorts too.
If it continues to play up, then a overheating fault will probably be traced to the power amp section. With something getting so hot that it will need to be replaced.
Sep 26, 2017 | Panasonic Audio Players & Recorders
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Our panasonic microwave keeps shorting out
It sounds like the power relay on the main control is shutting down. To fix this problem you would need to replace the control (Mother board). Before doing that the magnetron (heat element) should be tested to make sure that it is not what caused the relay to fail.
If you send me your model number I can try and get a ball part price on the parts you need.
Apr 24, 2010 | Panasonic Microwave Ovens
I have a Panasonic Toughbook CF-51. It fell off
i repair laptop every day and i have never seen and inverter board shut down the less it was total shorted. it sounds more like the fall my have damaged the hard drive. if a the drive wont spin it will cause the laptop to power down cause the little motor will over heat in a matter of seconds.if the laptop was on when it fell then its more than lickly the drive.
Feb 20, 2009 | Panasonic Computers & Internet
Panasonic Toughbook CF-51 shutting down
Sue, it's not the inverter board. People who don't really know much about laptops will often diagnose them incorrectly, especially computer repair shops. The problem you're experiencing is most likely related to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
Feb 20, 2009 | Panasonic Toughbook CF-51 Notebook
Spedomoter cable/and trany sencer broblem
You may have a problem with your speed sensor. I had mine replaced with a similar issue. I would take it to someone you trust if you do not know how to replace it. I had it replaced once....Then in about 9 to 12 months later I lost my transmission. I had the tranny replaced and then the speed sensor again because when it was being worked on and the garage had problems getting the tranny to work properly after replacing it. Later I was told that the tranny actually didn't need to be replaced; it was just another bad speed sensor. Needless to say I do not go there any longer so make sure you trust your mechanic before spending all that money for not. Hope this helps
Dec 11, 2008 | 2000 Dodge Caravan
TV panasonic TH42pd50u
It clould be either problem with Driver boards or Y-sus or powersupply itself
Isolate SU and SD board first and power up,then see What is happening.Then Isolate SD then SU.
Good luck
Sep 01, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic projection tv
panasonic is well known for two capacitors 1200pf 2k volts, also it has been known to short out the mosfet transistor, it sounds like you only need to replace the caps.
Dec 20, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-51g53w
Usually, when a Panasonic projection powers up for a few seconds and then shuts down, it is because one of the convergence IC's is shorted and drawing too much current. This is usually very easy to troubleshoot because the shorted IC causes one of the large reisitors near it to glow red hot just before the set shuts down. The set should be serviced by a qualified tech familiar with Panasonic projection sets.
Sep 02, 2007 | Panasonic PT-51G53 51" Rear Projection...
Panasonic TH-42PA20U/P 42 in. Plasma EDTV Logo
365 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
