Question about Toshiba 57H81 57" Rear Projection Television
Intermitant sound loss
While watching my television the screen will have very light diangonal lines flicker accross screen and the sound will go off. This will get progressively woorse over five to ten minutes. The sound will go off completely. If I turn the power off and then back on the sound will return and the problem will repeat. When the sound goes out if I push the mute button to get close caption it will be intermitant just like the sound.
    Sergeant:
  • 279 Answers
This is rather technical, but if you look at this PDF: http://www.tacpservice.toshiba.com/TACP/subpages/pdfs/TechBulletinsTV2003.pdf And scroll down to the 3rd page from the bottom. It will have No: TV200314 in its heading. That entry describes a known cause of sound loss on this model, and how to fix it. If you're not comfortable soldering on a circuit board, you may want to get someone else to take care of this for you. If you have any questions about it, let me know.
Posted on Sep 05, 2007
    President:
  • 3,130 Answers
This set has a few service bulletins out on different problems with this model. The biggest one is the bad solder connections on the negative lead on C809 and C810. If your able, you may want to re solder these as these will cause intermittent problems until these bad connections kill the Tv set. Good Luck
Posted on Jul 15, 2007
    New Friend:
  • 83 Answers
Have you set the video noise feature to , to high a setting? this will cause this problem,,,put it back to standard
Posted on Jul 09, 2007
SOURCE:
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a black line accross my LCD t.v. screen
if it is a thin black line then it is probably a line of pixels out. if this is the case, the whole screen will have to be replaced and that can get pricey. i would suggest that you get it checked out by a tv tech and get an estimate, but it'll probably be cheaper to just get a new one
Oct 21, 2008 | Televison & Video
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Toshiba 51h85c rear projection screen is red!!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 51H84 51" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Red Lines
Can you bring up the menu and see the menu over the red lines? Does the menu have red lines over it? I suspect the light engine is bad. Might want someone with experience to tackle that problem.
Jul 04, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung HCN653W 65 in. lines.....lines.....help!
My first guess is it kind of sounds like a convergence board problem i know they had some service bulletins on them. hope that helps oh and convergence boards arent exactly cheap and will probably require some soldering
Mar 22, 2007 | Samsung HCN653W 65" Rear Projection...
BLUE DOUBLE VISION
It sounds like you may have a loose solder connection either in the convergence circuit or the pincushion correction circuit. If you can't visually locate it, you may need a service manual and test equipment to track it down. I doubt that changing parts will be the cure if it is an intermittent problem.
Dec 16, 2006 | Samsung HCN473W 47" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
