Question about Panasonic PT-47WX42 47" Rear Projection Television
Half the picture is good, other half is off center
I turned on the tv today and noticed right away that half of the picture was out of alignment along with shocking green and pink colors on that side, however on the other side tv is normal, very hard to watch. Any clues on how to fix?
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directihalf the picture is good, other half is off center - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
half the picture is good, other half is off center - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
EmersOn TV has no picture when you turn it on, I noticed that the red light blinks 4 times after pressing on, I'm curious if that means something? Please help!
the 4 blinks are a error code means something wrong inside the tv
type your number and error code in google maybe point you in right direction
Jun 23, 2015 | Emerson Televison & Video
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Picture is distorted from center on my 65" Sony projection TV.
hi. this will be an easy fix for you if you are a good solder. you will need to replace the convergence chip that is located on the PC board(main). this chip is damaged and it has failed due to this damage that has occurred. click below for your new convergence chip(stk).
CLICK HERE
May 21, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Blurry edges
I own the same model of tv and have owned it for over 1.5 years. I moved with it twice. I had this problem about a month ago. On both vertical sides the screen became very fuzzy, yet the center remained clear. When turning the tv off and on I also noticed very wierd red, green, and blue lines streaming across the screen before the picture comes up or after it fades. I found no solution or cause to the problem. But I had two "long-boy" speakers from my panisonic 5.1 surround sound system setup right next the tv on either side. I set the center channel on top of the tv with the receiver on the shelf below. I thought well maybe some how the speakers were cause some sort problem in the tv. I moved the side "long-boy" speakers from directly next to the tv to about 6" away and removed the center speaker from the top of the tv. After several days of normal use of this configuration, the tv turned like normal and the fuzzy edges were gone. The symptoms lasted for around two weeks, and the several days after I moved my speakers. My only guess is that without a deguassing feature, it took several days for the magnitism to return to normal after repositioning my speakers.
Mar 17, 2008 | Samsung SlimFit TX-S3082WH 30" TV
Picture wandering to the right....
I suspect you have some filter capacitors failing in the power supply and/or the deflection circuits. It may actually be worth repairing this time! It could also be bad solder connections.
Feb 20, 2008 | Sylvania 6427FF TV
Constant clicking every half-second as soon as you plug it in.
I have the same problem-still troubleshooting...so far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Aug 29, 2007 | RCA F38310 38" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
May 07, 2007 | Mitsubishi WT-42315 42" TV
Panasonic PT-47WX42 47" Rear Projection Television Logo
88 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
