Question about Casio Watches
G shock 4778 alarm - Casio Watches
How to set time on Casio 4778.
This link should be able to help you. If you are trying to change analog time, you can find the answer on page 2.
http://mygshock.com/casio-manual/4778/
Mar 02, 2015 | Casio Watches
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
I have a casio g shock 4778 aw-590 and have lost the instruction manual and i need to change the anolog time
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4778.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 21, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
Mar 10, 2011 | Casio Watches
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Oct 01, 2010 | Casio G-Shock G2600 watch
I got my Casio G-Shock 4778 aw-590 battery replaced at a local shop(not a licensed g-shock dealer) and the jerks did not set the time and my manual for the watch was thrown out years ago!
mcdevito75 here, Return to the shop for this adjustment. Or you can try, press the mode button, see the display flashing, now press set for each function you want, after each function press mode again to move onto next function, hour minute etc., when all functions are set, presss mode again for steady display. You may have to press and hold down mode button from the start for 2-3 seconds to see display flashing, once you do, you can use set to adjust all functions.
Aug 17, 2010 | Watches
I have g shock 4778 aw 591. i need to change time on the dial but i cant can some one pls help me out?//
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIOwatch manuals.Rate me, please..
Mar 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I can't turn off alarm on casio g shock
Follow this link: http://world.casio.com/wat/download/en/manual/ Download manual for your watch and read how to turn alarm off.
Jan 12, 2010 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
101 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
