Question about Epson Office Equipment & Supplies
How to solve problem epson stylus photo t60 general error
Inky
  • 691 Answers
SOURCE: Epson Stylus Photo R320
Turn off the power and look inside the machine to the right hand side. Just in front to f the print head you will see a white plastic dowel (see photo). Use something technical - like a finger, pen or screwdriver - to push this dowel in. You can then move the print head by hand to the middle of the carriage.
Once moved, turn the printer on and watch it travel back to the home position. If after returning home the dowel pops back out and does not retract itself, you will need to strip the machine out and rebuild the ASF section. Sounds hard but its just a few plastic parts to take apart and reassemble whilst looking to see if anything is broken.
Get a service manual; for the machine HERE if you need to strip it out.
Posted on Sep 19, 2008
SOURCE: epson stylus photo r300 general
Hi--I had a BIG problem, day after day, fiddling with my Epson Stylus printer. The "General Error" kept repeating, and the two red buttons flashing each time I turned the printer off and on. There was nothing jammed at all. So, as a last resort I took a paper towel and ran it along the bottom of the inside of the printer (yeah--all technical jargon, I know--not a computer person here :-) and a bunch of black ucky stuff came up. MY PRINTER WORKS NOW! Hope this helps someone else. I saw a lot of posts where people said to throw out the printer and start fresh when my problem happened, but what an easy fix. GOOD LUCK!
Posted on Dec 23, 2008
websnail
  • 419 Answers
SOURCE: My Epson stylus photo RX585 tells me to switch it
This is a general error and usually it means that something serious enough to stop the printhead, paper feed or similar has happened.
Most of the time it's related to the printhead so here's a few things to check:
  1. Is the printhead able to move freely back and forth
  2. Is there anything blocking the printheads path, such as bits of ripped paper, etc...
  3. Are there any loose wires, cables, etc... that look out of place
  4. Is there ink splatter covering any plastic parts, or the strip that runs at the back of the printer? (more than normal)
  5. Is the printhead able to return to its normal parking position or is it being blocked by something.
  6. Are the cartridges inserted properly
  7. Have the chips on the cartridge(s) been soiled with ink or fallen off/out of position?
  8. Are the little wires that are located to connect to the cartridge chips, bent out of shape, or similar? (You need to look in the front/inside of the printer to check this).
Usually when you start applying these sorts of questions you identify a problem such as:
  • something that's jamming the printhead at a specific point
  • a wire has come loose
  • the parking pad has come out of its holder
  • ink has soiled a critical part like the calibration strip, cartridge chips, etc...
  • cartridge chip(s) has/have been damaged
  • the wires that provide the connection with the cartridge chip have been bent, broken or damaged.
Obviously that's a pretty long list of possible problems but hopefully it will at least narrow down what is going on in the printer so you can provide more information as to what it isn't or might be.
Hope that helps.
Posted on Oct 01, 2009
Testimonial: "Thanks for your reply, I'd already checked some of the things you mention but not all. Printer has now been replaced under guarantee."
SOURCE: General error for epson stylus T10
green & red light blinking cant print epson t10
Posted on Dec 07, 2010
SOURCE: general error in epson stylus
HOW TO FIX MY PRINTER, IT DISPLAY A GENERAL ERROR, AND BOTH RED AND GREEN LIGHT IS BLINKING.PLS HELP ME..TNX
Posted on Jun 14, 2011
My epson l800 write ,general error, open the printer cover and remove any paper inside the printer .turn the printer off and delete all print jobs ,turn the printer back on.am already try all but still...
Fix Epson Stylus Photo 6 Colors Printer General Error Problem
? 1:02
https://www.youtube.com/watch?v=Ci9MWG7zAkM
Dec 1, 2013 - Uploaded by TechRePair
Fix Epson Stylus Photo 6 Colors Printer General Error Problem. TechRePair ... ???????? Epson L800, T50, P50, R290, R295. User dismantling ...Missing: write
Epson General Error Problem + EPSON Adjustment ...
? 5:05
https://www.youtube.com/watch?v=gaKeB5JJqRc
Sep 28, 2014 - Uploaded by Gigi service
Epson General Error Problem + EPSON Adjustment Program / Waste Ink ... Reset Geral na Epson T30, T33, T50, T1110, L800, XP214, TX133 e ...Missing: write
epson l800 general error ' Error Help
Feb 10, 2015 | Epson L800 - printer - color - ink-jet
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Printer general error
you clean your printer rad and clean the all sincer
Feb 01, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
General error see printer documentation to clear error how do i do this
Epson T60 Printer shows the Cartrage and paper light on together and did not work?
Aug 06, 2011 | Epson Stylus Photo R320 InkJet Printer
Epson t60 general error
For a lot of Epson there is a remedy:
1. Turn off the printer.
2. Press and hold both 'stop' 'maintenance' and 'power' buttons for about 10 seconds.
A message will appear on the screen.
3. Power off and back on for reset.
Jul 28, 2011 | Office Equipment & Supplies
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
