Question about Brother Printer Wireless Monochrome Printer Dark Grey HL2280DW
Hl2280dw power supply - Brother Printer Wireless Monochrome Printer Dark Grey HL2280DW
Why does my brother HL2280DW printer say drum end soon
http://www.brother-usa.com/VirData/Content/en-US%5CPrinters%5CConsumer%5CUsersManual%5CUM_DCP_7060D_7065DN_HL_2280DW_EN_2864.PDF
Read page 39
Sep 09, 2014 | Office Equipment & Supplies
Where is the go button
The Go button is located below the 4 LEDs on the top of the machine to the left of the paper outflow tray, Marked Toner, Drum, Error & Ready. It normally has Go written above the button.
Aug 28, 2014 | Brother HL2280DW AllInOne Laser Printer
HL-2280DW says replace toner but I already have
Just do a manual reset:-
Open the front cover of the printer
Press and release the "clear" key
Press "start", then press the up arrow until you see the number 12 on the display
Press "ok", you will see "accepted" on the display
Close the front cover, your toner cartridge should now work.
Original Brother tonor cartidges should reset automatically.
Apr 17, 2014 | Brother HL2280DW: HL-2280DW Wireless Laser...
Brother hl2280dw replace toner stays on after putting in new cartridge
Press and release "start", then press the up arrow until you see 12
You will see "accepted" on the display
Press ok, then close the front cover
May 09, 2012 | Brother HL2280DW AllInOne Laser Printer
My Brother HL 2280DW Says replace toner cartridge but is not low and will not print.
Apr 30, 2012 | Office Equipment & Supplies
Ac adapter is red, what should i do?
This problem occurs when the power supply detects a problem. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if:
  • There is too much current.
  • The voltage is too high.
  • The temperature of the power supply is too high.
When any of these things happen, the light on the power turns red.
Solution 1: Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
  1. Turn the console off.
  2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
  3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
  4. After the power supply has cooled for two hours, reconnect the power supply to the console and to the wall outlet, and then turn the console on.
If the power supply light is still red, try the next solution.
Solution 2: Make sure that the power supply is plugged in loadTOCNode(2, 'whattotry'); Make sure that the power supply is directly plugged into a working wall outlet. Problems might occur with the power supply if it is connected through an extension cord or surge protector.
If the power supply light is still red after you connect the power supply directly to a working all outlet, try the next solution.
Solution 3: Plug the power supply into a different wall outlet loadTOCNode(2, 'whattotry'); To check the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a wall outlet that you know is working.
If this does not solve the problem, try the next solution.
Solution 4: Order a replacement Xbox 360 power supply loadTOCNode(2, 'whattotry'); If you've tried all the solutions above and your power supply light is still red, you should contact Xbox Support to order a replacement power supply.
To help the power supply work correctly, follow these guidelines:
  • Do not block any ventilation openings in the power supply.
  • Do not put the power supply on a bed, a sofa, or on any other soft surface that might block ventilation openings.
  • Do not put the power supply in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Do not put the power supply on a stereo speaker, an amplifier, or a heat source such as a radiator or a heat register.
  • Do not use an unlicensed accessory, such as a third-party power supply or any accessory that plugs in between the Xbox 360 console and the power supply.
  • Plug the power supply directly into a working wall outlet. The power supply might not work correctly if it is connected to an extension cord or surge protector.
hope this helps.
Apr 10, 2011 | Microsoft Xbox 360 Console
Brother Printer Wireless Monochrome Printer Dark Grey HL2280DW Logo
23 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
