Question about Toshiba (HDD2188) 80 GB Hard Drive
HDD2188 cannot display its volume
My usb harddisk which I have partitioned it into 2 cannot display the volume after I reinstalled my Windows XP with service pack 2. How will I be able to see these volumes I have in my USB HDD2188 now? My laptop is Toshiba Tekra. I already installed my usb drive but why is it my USB HDD cannot be browsed?
  • Naheem Santos Jul 10, 2007
    Good idea to format a harddisk via disk managment. Yes, my USB 2.0 HDD (Toshiba) 80Gb is new and should be plug and play right? Meaning, once it was inserted on a usb port the windows should show a drive and be able to format it. But the problem was that the windows do not show any drive for it. So formatting the drive cannot be possible. There should be drive first before to format.
Contact me on 0504671421- jeddah, will fix your hdd and can recover your data
Posted on Mar 02, 2008
  • 385 Answers
Hi, You might need to format them. Right click on MY COMPUTER, select MANAGE. Go to DISK MANAGEMENT, then to the right pane of the window, go to the usb drive and format each partition. This is only if your hard drive is new and has no data. If it has data, then it's a different problem and solution altogether. Thanks, Lolita
Posted on Jul 09, 2007
SOURCE:
Sir, i have hp mini 210-1000 laptop without cd/dvd. while installing windows xp i have deleted the partitions & tried to install xp from usb but failed. please help me to install windows xp .
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick.
The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed.
Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
Jul 10, 2011 | HP Mini 1000 XP Notebook
My acer aspire one netbook won't boot up. blue screen of death, stating there is a driver problem
try to load your windows in safe mode and then logon admin
then remove the display drivers then start the windows in normal mode.
Jan 19, 2011 | Computers & Internet
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
Lacie drive can't display in my computer
First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
Thanks.
Happy to help you.
Apr 24, 2010 | Microsoft Windows XP Professional
To create a recovery partition in harddisk
Unfortunately the Recovery partition could not be reacreated manually. But you can recover it by using the Y410 Recovery Disc but that means reinstalling everything and youll end up with windows vista again. You can reinstall XP but do not delete the partition that usually has 10-15GB of space because that is the hidden partition for the recovery. You can call 18774536686. If your computer is out of warranty, it would only cost you 59$ for the recovery disc
Jan 21, 2010 | Lenovo 3000 Y410 Laptop
How to reinstall linux os to windows xp...i can't install windows xp when i try to install error can't detect the harddisk but harddisk is on good condition...
There maybe a wiring connection problem with your harddisk drive to your motherboard. Check the power cord connection and also the connection to the motherboard. Try reconnecting the cords.
Oct 24, 2009 | Gigabyte Giga-Byte: 8I945P-G LGA...
Disk partition
My preferred solution is GParted. You can download this LiveCD and boot from it. The interface is fairly simple to understand. NOTE: It is important that after you resize a Windows partition you boot it up right away and allow it to scan the disk.
Feb 14, 2009 | Dell Inspiron 1501 Notebook
Install window on a portable ide harddisk
i dont think so dat window could b installed on usb.
Dec 31, 2008 | Computers & Internet
HDD Reformatting
why not reinstall sp3 again for windows xp if it freezes then it might be looking for files that don't exist anymore. If the virus attatched itself to your files they may have been removed when you ran your virus software. you don't need to format to reload windows. Just simply do a clean reinstall on C drive.
Oct 23, 2008 | Microsoft Windows XP Professional With...
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Open Questions:
BITDEFENDER toll free phone +$&{[email protected]*1O69} NuMbEr USA This BITDEFENDER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BITDEFENDER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.Anita
Oct 17, 2019 | BitDefender Computers & Internet
CHARTER helpline phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This CHARTER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 CHARTER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the CHARTER USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, CHARTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CHARTER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact CHARTER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CHARTER USA Calling CHARTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our desk call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CHARTER USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CHARTER USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CHARTER USA's phone numbers against each other. Contacting CHARTER USA in General While I8OO8O31O69 is CHARTER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CHARTER USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CHARTER USA.
Oct 17, 2019 | Best Computers & Internet
BULLGUARD toll free phone +$&{[email protected]*1O69} NuMbEr USA This BULLGUARD USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BULLGUARD USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the BULLGUARD USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.Anita
ROADRUNNER helpline phone {&$&{[email protected]*1O69} NuMbEr USA AsIf This ROADRUNNER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 ROADRUNNER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the ROADRUNNER USA helpline department for problems like Where to buy, Complaint, helpline, Repairs, Returns. As far as we can tell, ROADRUNNER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. ROADRUNNER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact ROADRUNNER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling ROADRUNNER USA Calling ROADRUNNER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our desk call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from ROADRUNNER USA helpline can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with ROADRUNNER USA's helpline department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare ROADRUNNER USA's phone numbers against each other. Contacting ROADRUNNER USA in General While I8OO8O31O69 is ROADRUNNER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach ROADRUNNER USA help by calling them, is that other techs give their helpline at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact ROADRUNNER USA.
See all Toshiba (HDD2188) 80 GB Hard Drive Questions
Toshiba (HDD2188) 80 GB Hard Drive Logo
285 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
