Question about Toshiba Remote Control SER0398 p/n:AH802703
Batterys for toshiba remote sero398 - Toshiba Remote Control SER0398 p/n:AH802703
I just bought a new remote and cannot find the user guide for the TV. Do you need to program the remote for it to work?
Hello
You have to programme it. do the following:
[1] Make sure there are working batteries in the Toshiba remote control.
[2] Turn on your television set, DVD player or other device that you want to control with the Toshiba remote
[3] Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
[4] Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
[5] Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
OK.
Jul 19, 2011 | Toshiba DC-SB1 Remote Control
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
TOSHIBA SER0324 Remote Control. I just got a Toshiba TV with this remote and I am unsure how to set it up.
Hello
You can prgramme with
toshiba remote control with Toshiba TV, eventhough you haven't its manual or codes. Proceedings are :
1. Make sure there are working batteries in the Toshiba remote control.
OK.
Mar 12, 2011 | Toshiba Televison & Video
What are the codes for a toshiba tv?
  • 1
  • 2
  • 3
  • 4
  • 5
  • Mar 09, 2011 | Toshiba Televison & Video
    I have an old remote that works for a VCR and I did have it working for the TV but one day someone was playing with buttons and it stopped working. I was wondering how to program my Toshiba vc 260 remote...
    Try the following procedure:
    5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed.
    Feb 28, 2011 | Toshiba Vc-260 Remote Control
    Toshiba remote uses lots of aaa batteries
    Dear please buy and put new AAA Battery.
    Jul 03, 2009 | Sony RM-TP501 Remote Control
    Remote range 1 ft.
    Try putting in a new set of batteries.
    May 19, 2009 | Toshiba CT-90157 Remote Control
    I can't program my Toshiba TV to the CT 91507 remote
    change battrries and select our old remote control codes
    Jan 19, 2009 | Toshiba CT-90157 Remote Control
    Remote
    Do the same remotes function normally ion other Toshiba TVs? Why don't you chech this out first? There is no possibility of the TV causing the above symptom. I can only think that you are using expired batteries.
    Feb 16, 2007 | Toshiba 36A41 36" TV
    Toshiba Remote Control SER0398 p/n:AH802703 Logo
    49 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
